Fender flare width question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Fender flare width question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAll Bilstein shocks & struts - Lowest Prices Ever and Ruffstuff Axle Simple Swap Kit!
Unread 03-10-2015, 10:10 AM   #1
PimaXJ
1997 XJ Cherokee
In researching the different types & sizes of fender flares for my '97, there is no middle ground as to width. Either it is the stock flare or the 5" wide style. There appears to be no in between size, perhaps 1-2" wider than stock. Anyone know of a source for such an item? TIA!
PimaXJ is offline   Reply With Quote Quick reply to this message
Unread 03-10-2015, 10:34 AM   #2
rugsucka
Make 'em yourself.
'00 XJ - Scampy the XJ
'10 Ram 1500 - Scampy's TB
rugsucka is offline   Reply With Quote Quick reply to this message
Unread 03-10-2015, 06:16 PM   #3
PimaXJ
1997 XJ Cherokee
I could make up something but it would look cobbled together when I was finished. My preference would be for something with an OEM appearance. If the factory flares were made of steel & money was no object, I could have a shop section them & widen them. Wishful thinking! Surprised that there is or was nothing like this offered, from Jeep or aftermarket.
Unread 03-11-2015, 01:58 PM   #4
PhilipJ
Originally Posted by rugsucka View Post
Make 'em yourself.
Yeah because everyone has the tools, space, accessibility to raw materials and the skilled capability to just make everything.
5" is quite a lot unless you've got wheel spacers/adapters or some exaggerated backspacing going on and stock isn't enough if you're running tires more than 10" wide. I just finished installing my HORE fenders, they're 4" and I've got 33's on 4" backspaced rims.
http://www.jeepforum.com/forum/f177/...l#post28845457
Build n' stuff: http://www.jeepforum.com/forum/f177/99-sport-build-thread-grocery-haulin-panache-1179209/
Cherokee Of The Month Winnar! - September 2012
PhilipJ is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 11:19 AM   #5
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
These stick out about 3.25 inches. -> http://www.napierprecisionproducts.c...V2-B-97-01.htm
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
