Fender Flare Help 97 Cherokee - JeepForum.com
post #1 of 3 Old 08-20-2008, 12:32 PM Thread Starter
jwaters77
I need some help. I took off my fender flares and in the process broke off all the bolts holding them on. Does anyone know where I can find replacement bolts and the metal that holts the flares on.
jwaters77 is offline
post #2 of 3 Old 08-20-2008, 06:13 PM
mlp187
It's been a while but I had that happen to my front flare on my 98... I had to grind out the bolts and my buddy used just standard nuts and bolts to hold everything in. Unfortunately I didn't see the process but they are holding up fine. I'll see if I can secure a camera to post a picture.
GOOD LUCK!
mlp187 is offline
post #3 of 3 Old 08-20-2008, 07:22 PM
liquidforceb069
liquidforceb069's Avatar
Mine did that too i just left them off. You might be able to drill out where they go through that little aluminum peice and just use regular bolts with nutters!
98 XJ Sport
8.5" BDS LA With Gas Shocks
Allied Rock 8 32Blt Beadlocks With 35" Trxus M/T's
RE Hack N' Tap
RE CVF Driveshaft 33.5" In Length
Warn Front Bumper With Winch
IPF Headlight Conversion
Drawtite Roof Rack
15% Tint All Around
Autolite Iridium XP Plugs And Wires
Optima Red Top
Tow Rig
2000 Dodge Ram 2500 Black
liquidforceb069 is offline
98 Cherokee sport fender flare brackets murattimucin XJ Cherokee Technical Forum 3 10-22-2009 09:13 PM
Fender Flare broke bolts 97 Cherokee jwaters77 XJ Cherokee Technical Forum 2 08-20-2008 02:49 PM
fender flare xjoverkill XJ Cherokee Technical Forum 3 05-02-2008 12:35 PM
fender flare for 97+ ??? black98XJ XJ Cherokee Technical Forum 2 02-11-2006 01:43 PM
Fender Flare...OY! JeeperSmurf XJ Cherokee Technical Forum 5 08-29-2005 12:23 PM
