Fender dent problem! - JeepForum.com
post #1 of 7 Old 10-28-2013, 10:14 PM Thread Starter
Trainhop91
So I some how managed to bend the fender next to the door. I know these things get beat up, but it's causing problems trying to open the door all the way. What's the best way to pull this thin out without messing it up more!? And again I've got no clue how this happened haha.
Trainhop91 is offline
post #2 of 7 Old 10-29-2013, 12:46 PM
BeauDuke01
1990 XJ Cherokee
shove a 2x4 between the unibody and fender skin through the wheel well, and twist it till it doesnt catch the door anymore
BeauDuke01 is offline
post #3 of 7 Old 10-29-2013, 11:49 PM
wassupjamesd
it happened to me too when i was in freezing weather. somehow the frozen water expanded something (hinge, plastic side molding on door). my dad kept pulling and pulling the door open, not knowing it pushed the fender in. i used a small crowbar with a piece of wood underneath for leverage. and gently pushed.
1999 Cherokee Sport 4x4, RE 3.5" SF, SYE, DS, and Monotubes, Pro Comp adj track bar. Soft 8s wrapped in 31x10.5x15 Dik Cepek Mud Countrys, Silverstars w/ HD harness, Class III rear hitch, Yakima snowboard racks, cool sunroof. NP231, C8.25, and D30.
wassupjamesd is offline
post #4 of 7 Old 10-30-2013, 02:45 AM
psychoteen101
Check to make sure the door hinge mounts on the body aren't coming off. Common issue with those sagging because of rust. Will cause the door to hit the fender and prevent it from opening all the way
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #5 of 7 Old 10-30-2013, 06:03 AM
1slosvt
Those door hinges can come off even without rust present. (Ask me how I know). It's a fairly common thing to happen to XJs. You may have to weld the hinges back to the body.
-2012 JKUS
-2014 GC Laredo
-2k xj
1slosvt is offline
post #6 of 7 Old 10-30-2013, 10:55 AM Thread Starter
Trainhop91
It isn't due to rust, as this thing was a grocery getter before I bought it lol. But I was wondering about the door sagging a bit. I still haven't been able to take a look at it but I will today.
post #7 of 7 Old 10-30-2013, 10:56 AM Thread Starter
Trainhop91
Lol so what happend to make your door come off? And I think the door was pulled down on causing it to sag enough to catch and bend it in.
