Fallon (and Dad) Novice Build Thread- '90 Cherry-Okee XJ - Input welcome! - Page 11 - JeepForum.com
 2Likes
post #151 of 363 Old 10-04-2013, 06:17 AM
EgulAye
1980 CJ5
What kind of rims are you looking for Scott?
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #152 of 363 Old 10-04-2013, 01:23 PM
ScroungerLee
Following along here, I wish I had more useful comments. No breather when spraying that axle?
Lee
ScroungerLee is offline
post #153 of 363 Old 10-04-2013, 03:21 PM Thread Starter
Skerr
Originally Posted by sAe23 View Post
Those type of compressors are meant for vehicles that have openings at the bottom of the spring perch (Mustangs for example, per my mechanic)...
Ahhh... I never looked in the case when I picked it up. Just assumed it was right. Thanks for clarifying that.
Found this page regarding "separation":
http://www.cherokeeforum.com/f67/upp...ration-162152/
As for track bars, probably any adjustable one should work... if you make your own just copy any of the designs on the market and measure your rig to get the basic length.
And you definitely need adjustable control arms! You'll never get the caster or pinion angle set right with stock arms at 6.5/7" of lift. Heck even with adjustable arms you have to sacrifice caster to get a decent pinion angle...
The link put me on to other pages that were even more helpful. Thanks again! Now my head is hurting from the tech reading!! Finding the trackbar measuring points is what is causing me to scratch my head. I was "planning" on welding two trackbars together to make it longer, but now I see drop brackets and adjustable heim joints. I think the heims would be desirable over ball-type joints (stock)???
Wellll, I'm not really looking for rims. Did I indicate I was? I'm having a brain cramp! I have some rims that are available...
Lee
*chuckle* I was wondering if/when someone would comment about no mask. Since we were outside and on the downwind side we didn't use one. I gave him one initially, but he felt he couldn't breathe with it on. So we took a HUGE breath and held it.
I wish you knew more too, because I need to know more myself! I'm glad you're here, though, and I'm looking forward to any comments.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #154 of 363 Old 10-05-2013, 07:17 AM
EgulAye
1980 CJ5
Maybe I'm the one with a brain cramp. I thought I read in the thread somewhere that Fallon was looking for wheels. I have to confess that I was reading through the entire thread to get caught up.
Moving on, I have a '92 Cherokee sitting here that I plan to pull the motor from for a future head swap into my CJ-5. What's left is headed to the JY. It's got the chrome mirrors, center overhead console, axles, tranny, fuel tank, etc... Need anything at all let me know. I expect to be sending it on it's was in the spring (no time for that project right now).
I'm super glad to hear you got Clay's CJ running tip top. I'd love to do a project like this with one of my kids, but their interest came to a stop after we all built computers from junk scraps. Now all they wanna do is play games
2012 JK
EgulAye is offline
post #155 of 363 Old 10-07-2013, 08:30 PM Thread Starter
Skerr
Attachment 733025
Explain to the kids that the car is operated by a computer!!
My boys waiver from one interest to another. If it is fun or cool then it is IN! Until something else comes along to replace it. We just installed a pool table, and that's what they want to do everyday! That and Airsoft.
If you didn't live on the other side of the Hood I would strip that XJ, BUT... I just don't know when I could find the time to get over there! However, if you have the time and inclination, I could use the chrome side mirrors (if they are decent- Fallon has them and one is busted). I could also use the right, front turn signal lens cover (the yellow piece- his is busted). AND, if you KNOW the overhead console is good, then I would request that too. Typically, the OH consoles fry-out after 20 years or so, and there is no resource for one around here. I was going to just go without.
Let me know what you want for all of that. Again, only if you have the time.
And I will close with this... I don't know what you will really gain from a 4.0 head swap. It seems to me that you will miss the benefit of the 4.0 engine, unless you're going to stroke it. The 4.0 swap into Clay's Jeep has been an eye-opening, miraculous change in performance of his rig. The only way I can think to further enhance it is to have a transmission designed for the rugged use of off-road and still shift like a street machine. His T18 pretty much kills any shifting efficiency. But I completely recommend that swap.
Thanks, Egul...
Edit*- If I had to choose only one item out of my list, I would choose the lens cover! Thanks, Dude.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #156 of 363 Old 10-07-2013, 09:01 PM
EgulAye
1980 CJ5
That figures about right, I busted it when I moved the Jeep out back. I know the chrome trim piece is cracked, pretty sure I got the lens too. I'll double check though and start pulling the mirrors. Is it okay that they are manual? They've each got the little joystick on the inside.
I'm pretty sure the OH console works, the PO was considering keeping it for his 79 Golden Eagle Cherokee but ended up not taking it.
Let's see how much it all weighs in a box. Maybe help with shipping, or not. Like I mentioned, it's headed for the JY. No loss to me if it's minus a couple parts.
From what little I've read swapping the head and manifolds over would give me the multi port fuel injection, which is built on a much more efficient head design. The 258 block would let me keep the low end torque, and my flywheel / clutch could stay the same ( I'd have to use the Hesco CPS kit) . I plan to keep the entire 4.0 HO engine though, in case that plan doesn't work well. Either way I'll keep the old head, manifolds, and carburetor so I can switch back.
I'm headed north on a hunting trip this weekend coming and won't be back until later in the week. Will that be fine on the time frame for those parts?
2012 JK
EgulAye is offline
post #157 of 363 Old 10-10-2013, 06:58 PM Thread Starter
Skerr
Good luck on the hunting trip!!
There is no rush for any of this. I still have to build the longarms, and I have more research to do. Manual mirrors is perfect. The OH console is quite long, and it may not be convenient to ship. Glad to pay the shipping, and glad to pay for the parts/time.
Thank you, Sir.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #158 of 363 Old 10-11-2013, 01:01 PM Thread Starter
Skerr
JIMINY CHRISTMAS! 2"X.250 round tubing is better than $9 a foot! Dang near $200 for a 20' stick. My dealer does not normally stock 2" thick wall, and I would have to special order it. Probably going to go with square. Dealer normally carries it, but he is out of stock at the moment. Why can't I use pipe instead of round tubing?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #159 of 363 Old 10-18-2013, 11:14 AM
EgulAye
1980 CJ5
Okay Scott, before I break this thing... Is it held in with clips, hidden screws, or something else?
2012 JK
EgulAye is offline
post #160 of 363 Old 10-18-2013, 11:18 AM
EgulAye
1980 CJ5
Oh, and this is the front passenger turn marker...
2012 JK
EgulAye is offline
post #161 of 363 Old 10-18-2013, 09:26 PM Thread Starter
Skerr
Attachment 767602
One screw in the front above the rearview, then push the whole thing backward towards the hatch. Or maybe pull it forward?? There is a metal lip that clips/slides onto the headliner body. Then it will fall out.
This is amazing! I can't believe I am getting chrome mirrors from Maine! Thank You. Thank You. Thank You.
Attachment 767634
Par for the course! I'll pass.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #162 of 363 Old 10-18-2013, 09:28 PM Thread Starter
Skerr
Picked up the metal for the longarms and crossmember this morning. $109. Not too bad. Planning on 3-linking the front. LOTS of research to do. Anyone that has experience building your own, length, bracket placement, crossmember, etc, etc, etc, I would be deeply in your debt to hear your expertise.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #163 of 363 Old 10-19-2013, 12:52 PM Thread Starter
Skerr
While surfing CL this morning, I found a front and rear axle from a Bronco. OP says front D44, manual hubs, and rear 8.8. Geared in 3.55. Says the axles are in great shape. $200 for the both of them. I wasn't entertaining the idea of axles, but I think this is a good price. I see where some of you have done this swap. I like the idea of manual hubs and the added strength. Thinking hard about it. It shouldn't be much more work to install these axles on the XJ, but what other things will come up... like driveshafts? What do ya'll think? I should pick them up in the morning, unless ya'll scare me off of them.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #164 of 363 Old 10-22-2013, 07:00 PM
EgulAye
1980 CJ5
Scott, PM me the mailing address you want the parts sent to. The mirror glass has some rust specks on it, probably from body panel sanding I think? I figured I'd leave the cleaning to you
2012 JK
EgulAye is offline
post #165 of 363 Old 10-24-2013, 11:36 AM Thread Starter
Skerr
Roger that... PM sent. Thank you, Dave.
Kerrdog
Go Fish! <*////><
Skerr is offline
4.0l , bastard pack , body repair , injector swap , xj
