Which engine block would you use? - JeepForum.com
post #1 of 16 Old 06-01-2013, 10:46 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
I have a 1988 4.0 with supposedly 80k miles on it. It's been sitting outside for about 6 months. I was told it ran fine.
The engine in my jeep has 240k miles on it and lost compression in cylinder 5 because the top edge of the piston has a chunk missing. It's had a main being knock too
It's my understanding there are not any changes in the cast of the 88 block and the 93 block.
I'm going to rebuild the entire engine which ever block I use. What are your thoughts?
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #2 of 16 Old 06-01-2013, 01:48 PM
BigBadWuf
1992 XJ Cherokee
Yes it will work, i helped a friend put an 88 motor in a 92.
But you must use the intake, flywheel, all sensors,throttle body, and distributor from the jeep the motor is going in. The only real snag we hit was how the coil bolts to the block, only one bolt hole lined up, which apparently didnt give the coil a good ground. So we had to hook a ground strap from the coil bolt to the head.
BigBadWuf is offline
post #3 of 16 Old 06-21-2013, 07:57 AM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Thanks for the input man. Picking up the rebuilt today from the machine shop.
post #4 of 16 Old 06-22-2013, 08:55 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
On my 88 block there isn't one hole for the coil... oh boy.
post #5 of 16 Old 06-22-2013, 10:53 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
The 93 has a better block. GO to Clifford, Or 505 Performance for a Stroker Kit get a nice cam and head while your at it since your tearing it down rebuild it with a stroker
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #6 of 16 Old 06-22-2013, 10:56 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Too late, 88 block is ready to drop into my jeep....
post #7 of 16 Old 06-23-2013, 07:11 PM
thedude30425
1989 MJ Comanche
Damn, You work fast!
thedude30425 is offline
post #8 of 16 Old 06-23-2013, 07:42 PM
Motorcharge
Not sure if you care, but technically an 88 motor in a 93 is a federal felony.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #9 of 16 Old 06-23-2013, 07:58 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
post #10 of 16 Old 06-23-2013, 08:01 PM
Tom95YJ
Tom95YJ's Avatar
Originally Posted by BassMasterCHS View Post
Federal law states. A vehicles engine must be of the same year or newer. Thus an engine from a 88 in a 93 will be illegal
Sent from AutoGuide.com App
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #11 of 16 Old 06-23-2013, 08:04 PM
04KJlimited
2004 KJ Liberty
as long as he uses all the 93 smog equipment I think he will be fine
04KJlimited is offline
post #12 of 16 Old 06-23-2013, 08:10 PM
Motorcharge
This. The odds of getting caught on it anywhere outside of CA are pretty damn low, but it's something to be aware of.
|SOLD|
| June 2015 COTM |
post #13 of 16 Old 06-23-2013, 08:45 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Huh, I can't see the difference... Specs are going to be the same and I will be using the same smog equipment. Same head too, which I would imagine makes the difference.
post #14 of 16 Old 06-23-2013, 08:46 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
What was the law intended to accomplish?
post #15 of 16 Old 06-23-2013, 08:55 PM
Motorcharge
88 is Renix era, less o2 sensors, different smog system, different exhaust, no on board diagnostic, ect, ect.
Overall reduction of emissions, which it doesn't accomplish at all. It's asinine and pointless burdensome regulation, but still something to be aware of in general.
|SOLD|
| June 2015 COTM |
