educate me on XJ shopping, please. - JeepForum.com
post #1 of 32 Old 06-23-2012, 07:47 PM Thread Starter
Bbasso
please delete thread.
Bbasso is offline
post #2 of 32 Old 06-23-2012, 07:56 PM
Motorcharge
The left is the NP-242, the right is the NP-231. 242 has full time which you can use on pavement, similar to AWD.
Most people prefer the 231 because there's a lot more aftermarket support for it, but they're both good. I'd prefer the 242 if I lived somewhere that it rained or snowed a lot.
No real difference in the trans between 99-01 iirc but the 00-01 motors can have the 0331 heads which are prone to cracking. The 99 doesn't.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 32 Old 06-23-2012, 08:02 PM Thread Starter
Bbasso
sorry, I ment Transfer cases...
I did know about the heads 0331, but it appears to be a small amount of cases.
thank you!
Bbasso is offline
post #4 of 32 Old 06-23-2012, 08:07 PM Thread Starter
Bbasso
If / when I do a 4inch OME lift, will either of them or none require special attention / parts?
Bbasso is offline
post #5 of 32 Old 06-23-2012, 08:11 PM
Motorcharge
You'll need an SYE more than likely, but you'd need it with either. I can only think of one company off hand that makes them for the 242 though.
If you're going to build it go with the 231. The 242 isn't worth it unless you're going to stay stock or close to it.
|SOLD|
| June 2015 COTM |
post #6 of 32 Old 06-23-2012, 09:10 PM Thread Starter
Bbasso
ok, here's an odd question... Did any of the 99+ Limiteds come with the NP-231?
Most of the ads I've looked at show the NP-242 and I don't plan on staying stock for very long. While it's not going to be a crazy build, I'm aiming for quality for longevity. Not headaches because of some odd part that doesn't have much aftermarket support. I'm sure you could understand.
My thoughts are the 4″ Super Ultimate XJ Old Man Emu But not sure which of the options: OME Hybrid Custom or Dual Rate Leaf Springs?? and for tires would be BFG A/Ts 31x10.5-15.
then there are the other things like sliders, bumpers, racks, lights, lockers... LOL!
AGAIN, thank you so much for the advice!
Bbasso is offline
post #7 of 32 Old 06-23-2012, 09:30 PM
ThatGuy57
2003 WJ
That model xj should have the 231 transfer case, I don't see why it wouldn't, I don't think limited's are much different then any other cherokees except asthetical features, I could be wrong however and as far as the lift, why not go for a 3 inch? You can still get 31's on there and you might not have to run an sye, no guarentee though. Just a suggestion. Good luck with everything.
If it ain't broke, it will be by the end of the day.
Past jeep- 98 white cherokee, 3" zone lift, 31x10.50 general grabber at2's, bds steering stabilizer, 15x7 soft 8's with 4" bs~R.I.P
ThatGuy57 is offline
post #8 of 32 Old 06-23-2012, 09:37 PM Thread Starter
Bbasso
I hope he doesn't mind me posting a pic of his beauty... But I fell in love with his XJ's stance. ( 4.25 lift & 31x10.5-15)
My goal is to get it close as I can.
Bbasso is offline
post #9 of 32 Old 06-23-2012, 11:25 PM
89xjchris
Most of the Limited's that i have seen have the NP242. I bet its because the limited was the fully loaded and the 242 was a option that cost extra.
Originally Posted by millhousenator View Post
can we just keep our ****ing comments to ourselves about whats a jeep and what isnt. Whether you like it or not its a jeep and he's on jeepforum. Jeeps are like boobs, some are big, some are small, some look fake and some look real, but they are still boobs so get the **** over it!
Originally Posted by bradyman1 View Post
Use duct tape. That always quiets the lady's down when they start kicking and screaming.
Originally Posted by Hunterdad View Post
And remember, anything that is camo is not gay.
89xjchris is offline
post #10 of 32 Old 06-24-2012, 07:39 AM
Motorcharge
This. And don't let it turn you off if you really want a Limited. It's not like there's no support for the 242.
|SOLD|
| June 2015 COTM |
post #11 of 32 Old 06-24-2012, 10:24 PM Thread Starter
Bbasso
Another question, probably been answered a million times. Sorry to ask.
To avoid the possible problems with the 0331 head, what was the build date they started to use them.
I heard Mid 1999 but no mention of a month.
I found a 1999 with the NP-231 and just about ready to pull the trigger, but worried about 0331
Bbasso is offline
post #12 of 32 Old 06-25-2012, 04:46 AM
rsurran
Read the 0331 head swap thread and then go buy your Jeep.
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
post #13 of 32 Old 06-28-2012, 03:00 PM Thread Starter
Bbasso
I found a super clean, no accidents 98 XJ with the np231 and a 5 speed... that I can afford.
QUESTIONS.
are there any downsides to the manual trans in the XJ's?
if it needs a clutch, can I (mechanically inclined) do it in my driveway? special tools needed?
thanks
Bbasso is offline
post #14 of 32 Old 06-28-2012, 03:59 PM
nate00
the top two bell housing bolts are an E-torx bolt (external torx, or star shaped). the bottom ones are normal bolts. thats the only special tool needed. other than that they are pretty simple
nate00 is offline
post #15 of 32 Old 06-28-2012, 04:06 PM Thread Starter
Bbasso
sounds easy even with those torx bolts, thanks!
One more question...
How do I tell from what axles are in it from just looking at it?
And the better/best are the Chrysler 8.25 correct?
Bbasso is offline
educate me on 4 wheel drive swells XJ Cherokee Technical Forum 3 03-18-2010 08:32 PM
educate me jodylikeamelody XJ Cherokee Technical Forum 4 05-07-2009 04:54 PM
swap car tech.. educate me about the renix ECU defrag010 XJ Cherokee Technical Forum 1 08-28-2006 06:08 AM
Educate me on FACTORY tow hitch/wiring BrokenLimits MJ Comanche Technical Forum 1 12-07-2005 05:44 PM
Please educate me in tire sizes.... latapx5 XJ Cherokee Technical Forum 10 02-22-2005 08:05 AM
