EcoFriendly xj? - JeepForum.com
post #1 of 13 Old 07-31-2014, 11:08 AM Thread Starter
jeepjunkie97
EcoFriendly xj?
Burned my hand on my black roof today. Gave me the idea of putting solar panels on, but not sure what to do with the power from it. Any suggestions?
jeepjunkie97 is offline
post #2 of 13 Old 07-31-2014, 11:31 AM
mschi772
1997 XJ Cherokee
http://driveev.com/jeepev/home.php
Sent from my phone
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #3 of 13 Old 07-31-2014, 11:49 AM Thread Starter
jeepjunkie97
Originally Posted by mschi772
Haa, definitely a unique build...
post #4 of 13 Old 08-03-2014, 07:34 PM
Worktruck
Heated seats
Worktruck is offline
post #5 of 13 Old 08-03-2014, 08:17 PM
mschi772
1997 XJ Cherokee
Sunny day in summer? Route the power to a ventilation fan to keep the inside of the Jeep from getting so freakin' hot. Sunny day in winter? Switch the panels to power heated seats (but only when you're there; heating elements running full-time with no one there could be very hazardous). Well, maybe not. I'd imagine heating elements would require more electricity than solar could provide especially in winter. I've seen people do solar ventilation, though--it really does keep interior temps down when the vehicle is parked in the sun.
mschi772 is offline
post #6 of 13 Old 08-03-2014, 10:54 PM Thread Starter
jeepjunkie97
The ventilation could peak my interest. Please explain more? I can imagine a thermometer inside set for a specific degree which once reached is wired to make a CPU fan turn on but idk if that'll really cool down the air trapped?
post #7 of 13 Old 08-04-2014, 03:42 AM
mschi772
1997 XJ Cherokee
Basically a fan mounted in the roof (they're designed for this, so no, they don't leak) that extracts the hot air. It won't keep the inside "cool," but it will keep it from reaching 500k degrees. Most of the ventilation fans out there are powered by their own small solar panels, but I'd imagine with a roof-mounted panel, you could run a really nice one. I honestly don't know what else you'd do with solar power on an XJ unless it was and electric conversion--solar just doesn't have a practical application for an ICE-powered vehicle.
mschi772 is offline
post #8 of 13 Old 08-04-2014, 10:05 AM Thread Starter
jeepjunkie97
Like a bathroom vent type of system?
post #9 of 13 Old 08-04-2014, 10:10 AM
mschi772
1997 XJ Cherokee
The better ones are like that, yeah. You can get little ones that are held in place by a rolled-up window, but they're not as good and can be a security liability. The roof mounted ones similar to household vent fans or ones that are common on RV's are nicer despite the downside of having to cut a hole in Your roof obviously.
Sent from my phone
mschi772 is offline
post #10 of 13 Old 08-04-2014, 10:12 AM
mschi772
1997 XJ Cherokee
I suppose you could also wire it such that it runs your HVAC blower. Some Priuses have solar panels that will cycle air through the parked car using the blower, but I'd imagine that would still work best if you had somewhere high for the hot air to escape as outdoor air is blown in.
Sent from my phone
mschi772 is offline
post #11 of 13 Old 08-04-2014, 02:00 PM Thread Starter
jeepjunkie97
Maybe get it to pulse each window motor so the windows crack and turns on an inside fan?
post #12 of 13 Old 08-04-2014, 04:58 PM
mschi772
1997 XJ Cherokee
Hell, why settle for one or the other. Power the HVAC blower AND a roof vent fan. HVAC blows in, roof vent extracts.
mschi772 is offline
post #13 of 13 Old 08-04-2014, 05:25 PM Thread Starter
jeepjunkie97
The only problem being would a solar panel truly collect and harness enough power to use these things more than a few cycles?
