EBC Ultimax Pads - JeepForum.com
post #1 of 14 Old 07-23-2011, 11:58 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
EBC Ultimax Pads
installed some ebc ultimax pads on the jeep last week along with new rotors. brakes did fine the first day and then after that at slower speeds, the pads squeal like crazy. higher speeds they perform great and don't squeal until i get to about ten mph. these just the nature of the pads? or do i need to uninstall and add some disc quiet?
97 XJ 4.0 Auto D30/29 Sp. 8.25. Yukon 4.10's
4.5" IRO Long Arm Kit - 33x12.50x15's
HD Offroad Engineering Shackle Relocation Brackets
Bilstein 5100's - Magnaflow Exhaust.
Cherokeekid88 is offline
post #2 of 14 Old 07-23-2011, 01:01 PM
GregB_00XJ
I would give it a little longer and see if it goes away. If they weren't bedded in properly or got glazed from hard stops right out of the box, you could get some squeal? They do say that they have a "special" coating to help with bed in? If it doesn't stop, take them back and get replacements.
My pads are Napa Premium and they always are a little squealy at lower speeds. Was thinking about swapping for a set of the EBC pads.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #3 of 14 Old 07-23-2011, 01:23 PM
Lynch_6913
I have always used the cheepest pads that were for sale. If you have new rotors you shouldn't get much squeek. I'd give it some time to maybe take some factory oil off of them, did you use brake cleaner on the new parts? also did you touch them with greasy or very sweaty hands? could be the cause. maybe give it 50 miles to wear off. if it doesnt id go with this guy ^^^
Lynch_6913 is offline
post #4 of 14 Old 07-23-2011, 03:03 PM Thread Starter
Cherokeekid88
1997 XJ Cherokee
im gonna drive it tomorrow and do some hard braking to try to break em in more
post #5 of 14 Old 07-24-2011, 05:55 PM
Wearingthin
If you didn't use any brake grease on the caliper bolts and slides, then you're gonna have the squealing issue like that
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #6 of 14 Old 07-25-2011, 08:21 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
I have installed brakes before not using anything, without any problems....but, I guess Friday since Im off work, I will just take them back off and make sure I grease up EVERYTHING!
post #7 of 14 Old 07-29-2011, 07:26 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
so i took the pads off last night and put some disc quiet on the backside of them. drove them this morning and still squeaking. could it just be the pads? maybe i should go with some regular napa pads or something?
post #8 of 14 Old 07-29-2011, 09:17 AM
GregB_00XJ
As mentioned, I run the Napa Premium pads, they have squealed a little since day 1. Not horribly, and less when hot, but they are still a bit loud.
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #9 of 14 Old 07-30-2011, 07:56 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
I bought some Napa ultra premium pads yesterday and what a difference....I feel the braking isn't as good with the ebc, but not more squealing...I just hate I wanted $60 on those ebc....
post #10 of 14 Old 07-30-2011, 10:18 AM
GregB_00XJ
Try and return them. I bet they will take them back?
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #11 of 14 Old 07-30-2011, 11:37 AM
jeepkid03
Winning
jeepkid03's Avatar
the squealing is a result of the material used in the pads. I have ceramic pads and they are a little noisy but my brakes are MUCH better.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #12 of 14 Old 07-30-2011, 01:29 PM
Wearingthin
X2
My EBC yellow pads squealed for a bit too. I don't hear them at all anymore
Patriot Blue XJ 4x4
post #13 of 14 Old 08-02-2011, 07:52 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
ok well, installed the napa pads and my braking is nowhere near as good as with the ebc's on. I called up the place I ordered them from and I told her that they were just way too noisy, but said that I couldn't return them because they are used. I really would like to reinstall the pads, but I am wondering, is there a way, I can maybe sand the pads good enough to remove most of the coating...because I honestly can't stand the squealing noise when driving.
post #14 of 14 Old 08-02-2011, 08:00 AM
jeepkid03
Winning
jeepkid03's Avatar
I have Hawk Performance Ceramic pads, they work awesome and the noise was only apparent the first day or so. I used Advance Auto ceramic pads on my mom's '05 Civic and they are much noisier.
-Josh
Build Thread:
What Brake Pads??? rdorazil33 XJ Cherokee Technical Forum 4 11-04-2009 10:02 PM
frt pads part no SL512651 XJ Cherokee Technical Forum 2 09-27-2009 04:16 PM
OME Friction Pads??? Khary23 XJ Cherokee Technical Forum 2 09-18-2009 04:17 PM
BEst Brake PAds for XJ DesertOne XJ Cherokee Technical Forum 12 01-23-2009 10:21 AM
brake pads? incubi67 XJ Cherokee Technical Forum 6 07-08-2005 05:56 PM
