E-15 to replace E-10? - Page 3 - JeepForum.com
post #31 of 47 Old 04-14-2013, 11:10 AM Thread Starter
94beachxj
1994 XJ Cherokee
Originally Posted by 222Doc View Post
the bad heads in the penta tick has nothing to do with fuel. I am sure Jeep would love to blame the fuel, void the warranty.
I can get 100octain unleaded, or 105 octain LEADED at about any gas station here. The latter is about 7;50$ a gallon. Just pony up.
I own a 2012 Wrangler with those so called "bad" Pentastar heads.
I used Real gas, and used the proper detailed "break-in" procedures that were in the Jeep's owners manuel.
At 16k miles,my Petastar engine is as/or more quiet that the ones I have seen with the head replacements.
I guess you could be correct, on the gas thing, but I have the Jeep to prove my points
$7.50 a gal???? hello. lol
Peace.
94beachxj is offline
post #32 of 47 Old 04-14-2013, 02:33 PM
dmill89
1995 XJ Cherokee
If you've got an engine that takes leaded, 100LL avgas is a little cheaper (~$6.50/gal) at most GA (general aviation) airports but it still isn't exactly "cheap". And since it isn't "legal" for on-road use you have to pump into cans, though the same applies to leaded racing fuel. Of course once you take it off-site you can do whatever you want with it.
dmill89 is offline
post #33 of 47 Old 04-25-2013, 10:29 PM
slickrocksteve
Unless you are in the great state of "Kalifornia". Where not all the nuts and fruits are on the trees,
If you get caught with leaded gas, even in your lawn mower, you are subject to a nasty visit from the AQMD.
And, I would bet they stick your Jeep, Truck, cars, weedwhacker....etal. Just to prove that you are a scofflaw.
Ain't the EPA grand?
I live in a very sensitive area for smog, and yes, I do remember the days you could not breathe because of the smog.
But adding alcohol, and other junk to our fuel causes the vehicles to use more fuel, so the amount of hydrocarbons, and CO2 would I think remain the same.
slickrocksteve is offline
post #34 of 47 Old 04-26-2013, 12:31 AM
5-90
5-90's Avatar
1988 XJ Cherokee
When did AvGas become outlawed on the street? I used to fill my Bug up with 112LL at Aretz years ago - had the heads mightily shaved, wouldn't even idle right on anything less than 100LL...
Ran like a raped ape on 110LL, 112LL, 120LL, and even 130LL when I could find it!
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #35 of 47 Old 04-26-2013, 03:49 PM
dmill89
1995 XJ Cherokee
Leaded gasoline of any kind has been illegal for on-road use since 1996 (as per EPA). Leaded gas is still legal for off-road use though (in most states).
Officially using leaded gas on public roads carries a maximum fine of $10,000 though it is not well enforced in most areas.
dmill89 is offline
post #36 of 47 Old 01-04-2016, 09:31 AM Thread Starter
94beachxj
1994 XJ Cherokee
Just heard the 15 % ethanol will soon replace the 10% current blend You guys like I that own old Jeeps will not like that!
In my owners Manuel they state that 10% is max on the ethanol thing.
I hope the Southern States here in Windsor Va continues to sell real gas! We pay up to 50 cents more per gallon, but we get 2-4 miles more a gallon!
Corn is a food imo!
post #37 of 47 Old 01-04-2016, 08:05 PM
Motorcharge
Corn is a food imo!
e15 has been around for several years. Definitely nothing new. The only stuff that I have a problem with it in is small gas equipment like lawnmowers and even then it's only a problem if you let it sit in a tank for a long period of time.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #38 of 47 Old 01-05-2016, 03:55 PM
mschi772
1997 XJ Cherokee
The only thing about this entire story of E15 going mainstream that I get stuck on is how it is a disappointing reminder that corporations and lobbyists run the country when it comes to the things that affect out day-to-day. This wouldn't be happening if the corn lobby wouldn't mislead and effectively own so many policy-makers.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #39 of 47 Old 01-05-2016, 10:18 PM Thread Starter
94beachxj
1994 XJ Cherokee
Not a fan of using Corn gas in outboard engines as well... Many feel it helps the injectors...... that is the Ethanol But I know some that disagree. And I hear some boat owners say they had to rebuild fuel components due to ethanol deteriorating the fuel system . Who knows......?
I do not care if they legislate 25% ethanol........I will just keep shelling out extra $$$ to get real fuels, and save a bacon Taco!
post #40 of 47 Old 01-10-2016, 12:14 AM
300cpilot
1995 XJ Cherokee
Hate to say it but our voices will not be heard. For those that want to separate the ethanol there is a video for it on youtube using water.
300cpilot is offline
post #41 of 47 Old 01-10-2016, 07:11 AM
mschi772
1997 XJ Cherokee
Phase-separated gas (using water to "wash" ethanol out) is contaminated and should never be used in engines. Not only does separated fuel create obvious problems, (E.G. poor performance and release of water into engine causing rusting of parts), phase separation will also distort the hundreds of other ingredients that gasoline contains. It also lowers the octane rating of the fuel.
The best thing you can do is to keep your fuel fresh by refueling often from busy gas stations. Never let E10 sit around for more than 3 months as it has a 90 day shelf life.
Ethanol isn't going anywhere, and we are a community of modders--consider modding your Jeep to handle E10 and E15 better instead of trying to mod the gasoline.
mschi772 is offline
post #42 of 47 Old 01-10-2016, 07:44 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
What changes would need to be made to our engine? Cuz mine runs like crap on ethanol. I've been paying for premium to avoid it. It runs great on premium though.
D3<!L!>3D
S8NNG8 is offline
post #43 of 47 Old 01-10-2016, 07:55 AM
ravenworks
Originally Posted by tjkj2002 View Post
The same reason they charged more back in the day when they started going to unleaded gas.They charged more to not put in lead.
Lead is not added during the refining process,to make unleaded gas requires an extra step to remove lead.
It cost more because it's made in limited quantities and storage is at a premium in most refineries.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #44 of 47 Old 01-10-2016, 10:16 AM
rebelbowtie
I think you have other issues, my 2.5 and 4.0 run perfectly fine on any grade of fuel with any amount of ethanol
rebelbowtie is offline
post #45 of 47 Old 01-10-2016, 10:50 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
You'd think so, but then why does it run perfect on non-ethanol fuel?
D3<!L!>3D
S8NNG8 is offline
