drive without ccv valve grommets in? - JeepForum.com
post #1 of 4 Old 06-12-2013, 12:42 PM Thread Starter
LITJGuy
so i just did my valve cover gasket and took off the old grommets and plastic elbows but they all broke, can i just cover them and take a quick drive to the stealership to pick up new ones?? or is this a bad idea
1996_XJ
6.5 on 35s
LITJGuy is offline
post #2 of 4 Old 06-12-2013, 05:05 PM
MossGreen97
1997 XJ Cherokee
Not a good idea. There is crankcase pressure in the valve cover that has to be released, hence the CCV system. You would probably have oil blow out some where. I had this happen on another vehicle in my youth. I replaced mine a while back and those grommets were a ***** to get out.Broke one of the elbows as well. I got a replacement elbow at Advance Auto. The elbows are different , so make sure you get the right one. I believe they have the grommets as well. Good luck.
'97 XJ Moss Green Metallic. 2DR. 2WD AW4 tow pkg.,3.73 gears. Firestone Destination A/T 225/75x15.
MossGreen97 is offline
post #3 of 4 Old 06-12-2013, 05:26 PM
dmill89
1995 XJ Cherokee
If you have access to another vehicle (or someone to give you a lift) that would be the best way to get the parts. If you have no other options duct taping coffee filters, paper dust masks (probably the best option if you have them), or gauze over the holes (don't seal them completely) would probably work for a short trip since it would still allow venting but keep crap from falling in the open holes.
dmill89 is offline
post #4 of 4 Old 06-14-2013, 10:16 AM Thread Starter
LITJGuy
just used some duct tape and took my short ride, didnt have any problems and the dealer had all new parts for me, worked out good
1996_XJ
6.5 on 35s
LITJGuy is offline
