Drain plug question - JeepForum.com
post #1 of 7 Old 03-16-2012, 10:52 AM Thread Starter
austin6137
1990 XJ Cherokee
Drain plug question
Ok so this weekend I'm gonna spray upol raptor liner on the floor of my xj. Now I pulled out my drain plugs before to rinse out the inside and reinstalled them. I was thinking of takeing them out spraying the floor and spraying the plugs on a piece of cardboard. I just wanna see what you other guys have done with your drain plugs. thanks
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #2 of 7 Old 03-16-2012, 11:52 AM
Metro55
I would just leave those unsprayed..spray the floor and then reinstall them
.,,_____,====,
//__l_l_,\____\,_____
l_,--\_l__l_/--|[]llllll[]|
,()_),,,,,,()_)--o-)_) Caged
Metro55 is offline
post #3 of 7 Old 03-16-2012, 12:24 PM Thread Starter
austin6137
1990 XJ Cherokee
Yea, I think it would look wierd to have two unlinered spots thou
post #4 of 7 Old 03-16-2012, 12:29 PM
Metro55
But their drain plugs... I would leave them
.,,_____,====,
Metro55 is offline
post #5 of 7 Old 03-16-2012, 06:01 PM Thread Starter
austin6137
1990 XJ Cherokee
Ok another question, I had sprayed duplicolar bed armor on some spot on my floor. I used a wire wheel in my drill and its not coming off so easy. If I just get most off and wipe it all down with acetone will that cause a problem?
post #6 of 7 Old 03-16-2012, 06:15 PM
lilnapsak
1997 XJ Cherokee
shouldnt..
but leave the drain plugs how they are. its just going to fall off ater squeezing the plugs in and out anyways.
i find drain plugs to be pointless.. for a wheeler. once water gets a little higher than the doors water finds its way in other ways. mine are perminately removed and i also added a few more so when i do get water in my jeep it just drains out as soon as i get out of the water/mud. i do get a slight draft up my leg from time to time though
lilnapsak is offline
post #7 of 7 Old 03-16-2012, 06:24 PM Thread Starter
austin6137
1990 XJ Cherokee
I gotta keep the drain plugs, it won't pass inspection other wise ask me how I no.
Radiator is leaking from top "plug" (not drain plug) jmpetre XJ Cherokee Technical Forum 16 08-03-2017 05:25 PM
Cant get coolent to drain, help with drain plug please JayBanion XJ Cherokee Technical Forum 14 06-10-2012 06:48 AM
Question about oil drain plug fix rompinthewoods XJ Cherokee Technical Forum 4 11-28-2010 11:29 AM
Oil drain plug--someone has to be right. sn86 XJ Cherokee Technical Forum 4 07-16-2010 07:55 PM
'88 Diff Plug/Block Coolant Drain Plug sroodtuo74 XJ Cherokee Technical Forum 2 09-26-2004 03:49 PM
