Quantcast Dont know what to buy with my 150$ someone help me! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > Dont know what to buy with my 150$ someone help me!
Old 02-08-2010, 07:10 PM   #1
DylanYazel
OK so I sold a touch screen radio, and have 150 bucks of it to spare what should I buy for my 2000 xj sport? I have a 4.5" add a lift and have really wanted to buy a 1.75 coil spacer/shackles lift to give it just a bit more. I really want to save for an off-road front bumper though to.... hmm someone help me! If I get the coil spacer and shackles will i have to pay for someone else to do the coil spacers? Is it easy to install?
Give all your worries to the lord and he will comfort you
DylanYazel is offline   Reply With Quote
Old 02-08-2010, 07:27 PM   #2
keepishop
keepishop's Avatar
1989 XJ Cherokee
Coil spacers are easy if you know how to use a wrench.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline   Reply With Quote
Old 02-08-2010, 07:35 PM   #3
DylanYazel
keepishop i know how to use a wrench but will i have to go rent some coil condensers or whatever they are called from o Reilly's? I can install the shackles those are easy but how hard is it gona be for the coil spacers? I have to remove my front wheels i imagine?
Old 02-08-2010, 07:46 PM   #4
303_XJ
I would much rather install coil spacers than shackles. My leaf spring bolts were seized so tight that I gave up on them and figured out how to do my lift with the leafs still attached.
If I had an extra $150 I would get these Amazon.com: KC HiLiTES 121 SlimLite Black 130-Watt Long Range Light System: Automotive
Colorado Jeep Club Member # 208
303_XJ is offline   Reply With Quote
Old 02-08-2010, 07:49 PM   #5
DylanYazel
Thanks bro how did u do the coils? Did you rent a coil condenser thing from the store?
Old 02-08-2010, 07:55 PM   #6
303_XJ
No, I bought a set of coil compressor's from Harbor Freight for like $10. They really sucked. But that would really help so you dont have to 'droop' the whole axle and get them in. I bought mine then gave up on them and just lowered the axle enough to get the new springs on. I bet that would be difficult now with the bigger springs.
Old 02-09-2010, 06:35 AM   #7
Kevin108
Back from the dead @ 167k
Kevin108's Avatar
A JeepForum membership?
It took me a while, but I finally figured it out: catastrophic failure and
the subsequent repairs is the Jeep thing they're always talking about.
Kevin108.com | My 2000 XJ Build | Hampton Roads Jeep Club
How to reindex the camshaft position sensor on an 00-01 XJ
Tips on trimming 97+ XJ bumper end caps and lower facia
Kevin108 is offline   Reply With Quote
Old 02-09-2010, 10:19 AM   #8
p2y2r7o
1997 XJ Cherokee
Ha, exactly what I was gonna say. (or buy me one)
1997 Cherokee Country - RED
p2y2r7o is offline   Reply With Quote
Old 02-09-2010, 10:41 AM   #9
Curt41
Quick discos if you don't already have them, but definitely a JF membership.
Curtis
Check out my build thread
Survivalist Jeep #6
Rusty's 3in Full leaf pack, JKS quicker discos, rear sway bar gone, Carr light bar with 4 KC 6x9's, C4x4 Tow Hooks, Flowmaster Super 44 Off Road Muffler, 31x10.50 Goodyear Dura-Tracs
Looking for a set of pre-96 XJ front bumper endcaps
Curt41 is offline   Reply With Quote
Old 02-09-2010, 11:13 AM   #10
jeepkid03
Too Good
jeepkid03's Avatar
If it were me I would save it towards something bigger I might need, like gears or something. Or keep it incase something breaks. Its always good to have extra cash layin around. Seems like everytime I spend money on the jeep for something I don't REALLY need, then something else totally unrelated breaks.
The KC lights posted above are a good idea if you need some lights, as well as the JF membership others have mentioned. Could also put it towards maintaining the jeep so it lasts longer.
-Josh
XJs are the greenest vehicles out there. They put oil BACK into the earth while parked. :D
You can run WD-40 in a Jeep 4.0 and still get 200k miles out of it.
Build Thread:
http://www.jeepforum.com/forum/f22/moaning-brunette-build-1119997/
jeepkid03 is offline   Reply With Quote
Glock Forum
