Doing the Headlight Upgrade on my XJ! - Page 3 - JeepForum.com
post #31 of 72 Old 08-14-2013, 10:42 PM Thread Starter
zaxfire69
Holy COW!!! Now I see why you guys say this is the best Mod you can do for an XJ. UNREAL!! Video to follow..!!
zaxfire69 is offline
post #32 of 72 Old 08-14-2013, 11:16 PM
1997xj
1997 XJ Cherokee
x2! Put a harness together using the gojeep instructions and just installed it. I haven't even put the H4s in and its amazing. Should have done this the day I got the xj
1997xj is offline
post #33 of 72 Old 08-15-2013, 12:20 AM
AKIQPilot
Great info here guys, thanks a bunch. I have a 30" light bar but I think this would be a great mod even for my rig. Thanks for the links to the harness and H4's.
I am thinking 80/100 bulbs for me. My rig is off road only so I don't worry much about oncoming traffic.
AKIQPilot is offline
post #34 of 72 Old 08-15-2013, 04:47 AM Thread Starter
zaxfire69
I know my accent is strong. I'm from the country.
My video.
http://youtu.be/dAmlgwrjtXw
post #35 of 72 Old 08-15-2013, 07:26 AM Thread Starter
zaxfire69
What could I do to remedy the power drain on my vehicle when I turn on high beams? You can see in the video when I turn the high beams on I experienced a little voltage drop.
post #36 of 72 Old 08-15-2013, 07:04 PM Thread Starter
zaxfire69
Before...Sad...
After!!! Whoop Whoop!
post #37 of 72 Old 08-15-2013, 07:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by zaxfire69 View Post
Attachment 657774
Before...Sad...
Attachment 657775
Amazing and cheap, isn't it?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #38 of 72 Old 08-15-2013, 09:11 PM Thread Starter
zaxfire69
Bulbs $20
Harness $40
Housings $95
$155 altogether. Well worth it. Now I need to beef up the electrical to handle the extra load. Going to do the big 3 next. Then eventually get a higher amperage alternator.
post #39 of 72 Old 08-15-2013, 09:20 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Bulbs $20
Harness $40
Housings $95
From www.kelleyswip.com?
post #40 of 72 Old 08-15-2013, 10:22 PM
WheelinCowboy
1989 XJ Cherokee
Bulbs $20
Harness $40
Housings $95
What's the "big 3"? Haven't seen or heard that term before.
1989 Cherokee (XJ) I6 4DR 4X4 Stock... for now
2002 Grand Cherokee Overland- Blown Motor *SOLD*
WheelinCowboy is offline
post #41 of 72 Old 08-16-2013, 05:49 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Way better cables from www.kelleyswip.com I'm guessing.
post #42 of 72 Old 08-16-2013, 08:27 AM Thread Starter
zaxfire69
It is installing Larger diameter cables on 3 key spots on your vehicle. I learned how to do this installing car stereo systems some years ago. Guys that have amplifiers that pull a lot of current usually do this trick. I figure that it would also work for us XJ guys that run alot of lights or compressors or any thing that draws extra current from our electrical system.
1st- Your ground from your engine to your frame. Can also put a cable from your Negative post on your battery to your frame as well.
2nd- From your Alternator to your Positive post on your battery. It is best to have an inline fuse on this run of cable, just incase it makes contact with metal and causes a short.
3rd- From your positive on your battery to your Fuse box under the hood. It allows more current to travel through your electrical system.
I used 0 Guage on my Honda Civic when I did it on it. I drive it daily.. I figure 2-4 guage (awg) would work as well.... I had about 4,000 watts of amplifiers running 2 15" subwoofers in a wall..I figure it will work on an XJ as well. Couple the big 3 with a larger output alternator and that should clear up any electrical issues...What do you guys think about THE BIG 3???
post #43 of 72 Old 08-16-2013, 10:07 AM
evo_ski
I am really surprised more people don't do the HID projector route. No matter how much engineering and money designers dump into a reflector housing it will never be as good as a projector. The beam from a projector is much more crisp, puts the light in places you need it much better and doesn't shoot light where you don't need it. There is a reason that almost all new cars regardless of whether or not they are HID or halogen use projectors rather than reflectors. A projector can shoot a much more even beam than a reflector can and doesn't shoot any light above the cutoff so it doesn't get in the eyes of oncoming traffic.
I just purchased everything I will need from a harness, projectors, HID kit, and new housings to hack up to install the projectors into and so far my total is at $95. I will make sure to post my results when they are completed, but personally I think bixenon projectors are a much better way to go.
evo_ski is offline
post #44 of 72 Old 08-18-2013, 06:46 AM Thread Starter
zaxfire69
If you are running Sealed Beams on an XJ you are missing out on turning Night into Daylight. Lights are so bright. I should have done this years ago!
post #45 of 72 Old 08-18-2013, 06:48 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yep. For under $100 you can see at night and not worry about melting headlight switches ever again. and we all know when they melt down. At night!!!
