does anyone regret takin out carpet? - JeepForum.com
post #1 of 11 Old 07-24-2008, 07:17 PM Thread Starter
blue92cherokee
1992 XJ Cherokee
So i was just wondering if anybody has taken out their carpet and regrets it? not sure about how noise or heat is affected should i go for it
blue92cherokee is offline
post #2 of 11 Old 07-24-2008, 09:14 PM
bigbike
1995 XJ Cherokee
I took mine out and it was getting really hot so i put the front back in.
bigbike is offline
post #3 of 11 Old 07-25-2008, 09:11 AM
kadetklapp
1997 XJ Cherokee
I collect Caprice police cars which are sometimes ordered with "6A3" or the rubber floor option. I find this easy to clean, good looking, and worry free as far as maintenance is concerned. I understand many state-bid XJs were available with the rubber floor option, and I recommend getting one from a yard or something. Nothing like a muddy floor gettin sprayed out with a hose and a generous amount of tire shine applied!
kadetklapp is offline
post #4 of 11 Old 07-25-2008, 09:28 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
If you are using the Jeep for daily driving, I would recommend leaving the carpet in. There is a significant increase in heat output as well as noise increase without the carpet/padding to go with it.
If you are using the Jeep for Off-road only, then the carpet is merely in there to collect moisture and dirt.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 11 Old 07-25-2008, 10:21 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Why are you wanting to take it out? if it's to fix some rust you could take it out, repair the rust, herculine the floor, then put it back in. at least that's my plan.
xjfever is offline
post #6 of 11 Old 07-25-2008, 10:46 PM Thread Starter
blue92cherokee
1992 XJ Cherokee
at first i wanted to take it out just for easy cleaning but then someone poured milk in my window and it stinks nasty so its coming out to get a good hose off this weekend. just trying to decide if i should just leave it out. sounds like i should do like your thinking. herculine then carpet back in. thanks for all the input everyone
post #7 of 11 Old 07-25-2008, 10:50 PM
XJ90
well just my 2 cents, i expected a big difference when i took out my carpet, but i haven't noticed that much. the only big noise difference is because i found a hole in my floorboar; bout the size of a half dollar, that is pretty much right at the end of my muffler(it's dumped at the axle) but heat wise, hasn't been a difference....or maybe that's just cause it's been around 100 now......so i actually use my a/c but i plan on fixing that hole, and bed line the whole inside
XJ90 is offline
post #8 of 11 Old 07-26-2008, 12:44 PM
jebmccall
1997 XJ Cherokee
i tore mine out because it was soaked with mud and water and it smelt nasty!!!!!!!!!!!!!!!!!!!!!!!!!, it is a little bit hotter in their especially around the transmission, but its easier to clean, and you can knock out the drain plugs and get some redneck airconditioning.
jebmccall is offline
post #9 of 11 Old 07-26-2008, 08:33 PM
littleblackXj
1993 XJ Cherokee
I took mine out and bedlined the inside of my jeep. I cut the carpets out so i can put it back in and have it still look nice. So far though the bedliner works fine.
1993 Jeep Cherokee
Rubicon Express 4.5" Lift
33" Wrangler Duratracs
30/44 4.88s Disks all around
Rear Detroit/Open front
littleblackXj is offline
post #10 of 11 Old 07-30-2008, 01:14 AM
el_magico
1995 XJ Cherokee
I just bought my XJ from some old lady. She was a smoker so getting the smoke smell out was a chore, but i got it out. Now i find that Jeep used to be the habitat of probably several mice. So now the chore is getting the mice piss and crap smell out.
Well i though i would remedy that by spraying some industrial deodorizer all over the interior before me and some friends took it out for the first time. what did that accomplish? Well, on top of everything else we got stuck in some nasty stagnant muddy water, so now the interior smells like a someone left their muddy bowling shoes in the Jeep for the mice to piss and crap in.
the carpet will be out by saturday, it is beyond repair. LineX is the way to go.
el_magico is offline
post #11 of 11 Old 07-30-2008, 10:12 AM
hxcjohnny
wow. haha. sounds like that jeep has had quite a life!
02 WJ Overland
hxcjohnny is offline
NEVER takin the jeep on the freeway again!!! 96-XJ XJ/MJ Cherokee Non-Technical Forum 16 12-13-2009 10:04 PM
takin' off the doors idea... MrZucchinihead XJ Cherokee Technical Forum 9 09-21-2009 03:13 AM
Tire Regret? TheGnu! XJ Cherokee Technical Forum 6 06-03-2005 12:13 AM
takin stuff off...good idea?? oldschool8604 XJ Cherokee Technical Forum 6 04-04-2005 08:30 PM
Buyers Regret phokur XJ Cherokee Technical Forum 10 07-10-2004 11:12 PM
