Devil liveD: Building S8NNG8 - Page 87 - JeepForum.com
 2Likes
post #1291 of 2758 Old 05-06-2014, 11:49 AM
Luke95
Originally Posted by S8NNG8
Fortunately, our good yard does nationwide searches and will ship cheap. As far as the welding, what I know is how easy it is to go into a seizure when I have strobing lights in my face
I got another issue, is there a way I can check, tighten, and install(possibly missing) Flywheel bolts without total teardown and separation of my transmission?
It's quiet easy for you to pull the cover and check them!
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #1292 of 2758 Old 05-06-2014, 12:51 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I'm not seein' that. I have to pull the exhaust, even if the bell housing would slide out. Or is it the plate on the front side you're talking about?
D3<!L!>3D
S8NNG8 is online now
post #1293 of 2758 Old 05-06-2014, 01:17 PM
8pitcher
8pitcher's Avatar
If you have a manual which you do because you said flywheel. You gotta pull the clutch off to get to the flywheel bolts that are then underneath the clutch.
8pitcher is offline
post #1294 of 2758 Old 05-06-2014, 01:26 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I went to a tranny shop this morning and had the owner ride with me. I was hoping he'd be wrong about needing a rebuild or replacement, $1000 or $1700. I did my own clutch, but I guess if it were the flywheel, my clutch would show signs by acting up. And as I said before, if you ignore the sound, you'd never know anything was wrong.
D3<!L!>3D
post #1295 of 2758 Old 05-11-2014, 10:30 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
It looks like I'll be getting a new transmission. I can do the install myself with a buddy. It'll be one more thing marked off the list of neverdoneit. The sound is getting worse by the day, so I just hope it'll get here soon enough to keep me from being stranded. I really don"t wanna see what could happen if it locks up on me.
In my attempt to avoid the problem, I've been using neutral a hell of a lot more lately while coasting or slowing down.
D3<!L!>3D
post #1296 of 2758 Old 05-22-2014, 10:26 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I went to the transmission shop to get the diagnostic check done before I pulled the trigger on buying a transmission. Up on the rack, in gear, 4hi, nothing can be heard except a light grinding in the rear axle.
D3<!L!>3D
post #1297 of 2758 Old 05-22-2014, 10:11 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
So I keep telling the the guy at the tranny shop, "I don't know anything about this ****, THAT'S WHY I CAME TO YOU!" And then he says, "Well, pull the rear diff cover and see if the problem is there."
UH, I DONT KNOW WHAT I'M LOOKING FOR! They'd best not plan on charging me $85 to figure out nothing.
D3<!L!>3D
post #1298 of 2758 Old 05-22-2014, 10:19 PM
8pitcher
8pitcher's Avatar
So I keep telling the the guy at the tranny shop, "I don't know anything about this ****, THAT'S WHY I CAME TO YOU!" And then he says, "Well, pull the rear diff cover and see if the problem is there." UH, I DONT KNOW WHAT I'M LOOKING FOR! They'd best not plan on charging me $85 to figure out nothing.
Pull the cover and check for metal and anything that looks like it shouldn't. Don't take it to a shop and have them do it they'll charge you everything you got.
8pitcher is offline
post #1299 of 2758 Old 05-22-2014, 11:00 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
When they first suspected the front axle and assumed a full rebuild, they quoted $2600. I said, "You're nuts, I could buy another XJ for that much!"
And he said, "A what?"
Pshh, *******!
D3<!L!>3D
post #1300 of 2758 Old 05-23-2014, 07:41 AM
Luke95
8.25 is your new friend. 3.07 ratio is what you need.
Luke95 is offline
post #1301 of 2758 Old 05-23-2014, 07:50 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Right. And from what I know, that means I just need to get it from a 4.0/5spd, correct?
D3<!L!>3D
post #1302 of 2758 Old 05-23-2014, 07:51 AM
Luke95
Yes or get both axles from an auto
Luke95 is offline
post #1303 of 2758 Old 05-23-2014, 07:53 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I don't suppose any 4cyl got a 8.25 or a D44.
D3<!L!>3D
post #1304 of 2758 Old 05-23-2014, 07:54 AM
Luke95
I couldn't tell ya
Luke95 is offline
post #1305 of 2758 Old 05-23-2014, 08:04 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Well, I got the day off, so I guess I can check the yards today.
D3<!L!>3D
