Devil liveD: Building S8NNG8 - Page 68 - JeepForum.com
 7Likes
post #1006 of 2977 Old 12-04-2013, 11:28 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Originally Posted by IDIdiesel View Post
Just a tip on that hack saw blade, take a paint mixing stick and break it in half. Tape the blade to the stick for a nice handle
About 3/4 of the way through I went and bought one those handles that holds a blade. But the paint stick is a cool idea.
D3<!L!>3D
S8NNG8 is offline
post #1007 of 2977 Old 12-04-2013, 02:25 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I'd have to say it's so close to matching I can't complain. This color gives off a different hue depending on the angle you're looking at it.
D3<!L!>3D
S8NNG8 is offline
post #1008 of 2977 Old 12-04-2013, 04:13 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Well, it's time to put all of my mods on hold. My cooling system is screwed. I've known my radiator has a leak. The outlet for the overflow is cracked rendering the overflow useless. But now I don't know if it's my water pump, thermostat, or my head gasket.
D3<!L!>3D
S8NNG8 is offline
post #1009 of 2977 Old 12-04-2013, 07:14 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Based on local prices, I'm looking at $460-$760 depending on the condition of the head.
D3<!L!>3D
S8NNG8 is offline
post #1010 of 2977 Old 12-05-2013, 05:39 AM
DNFJ
What? If your rad is leaking just replace the rad.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #1011 of 2977 Old 12-05-2013, 09:07 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I've been pampering the problem for months. But with the weather being so cold lately, it went to hell. It overheated yesterday, so I pulled over at the last store before you head out of town to where I live. I let it cool down, filled it with antifreeze, left the store and noticed large amounts of white smoke coming out the tailpipe. And 2 miles later it overheated again. Waited again and limped it the last mile to the house.
Of the list of possibilities, I'd prefer to just fix them all: radiator, hoses, water pump, thermostat, and head gasket.
D3<!L!>3D
S8NNG8 is offline
post #1012 of 2977 Old 12-05-2013, 02:06 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Couple months back the ZJ fan clutch I was running got into my radiator. Don't know about the head gasket - but I just replaced my entire cooling system (rad, rad cap, upper/lower hoses, fan clutch, t-stat, water pump, and a fan shroud that I never had). Most the stuff I found on Amazon, the rest at O'ReillyAuto. All of it run-a-the-mill oem replacement stuff, nothing special, but it gets the job done. I even swapped in BrownDog poly mm's and I did it all for under $300 - including the coolant.
Whatever that $460-$760 includes - shop around because what you want to do can be done for a lot less.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #1013 of 2977 Old 12-05-2013, 06:50 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Somehow I knew that finding this visor was gonna be a curse. It's looking like the plan will be to replace the engine, but it won't be happening for about a month from now.
I can't even get it to the shop tomorrow to get the visor put on, along with not being able to work. What a nightmare.
D3<!L!>3D
S8NNG8 is offline
post #1014 of 2977 Old 12-06-2013, 08:04 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I've decided to go out on a limb and try doing this cheaper. The radiator is getting replaced next week. We'll see if that fixes the problem. The motor is showing no signs of suffering from a bad head gasket. It runs fine and idles the same.
D3<!L!>3D
S8NNG8 is offline
post #1015 of 2977 Old 12-08-2013, 11:39 AM
Camfam07
yeah check your coolant for weird colors and oil in the coolant, other than that listen to JEEPN4KC post alot cheaper to start with the little things. my water pump always makes a grinding noise when it goes bad, but they are cheap and easy enough to change you might as well.
Camfam07 is offline
post #1016 of 2977 Old 12-08-2013, 11:58 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
The radiator is getting done only cuz my dad has the money to do it.
My uncle is the one who offered to replace the whole engine, cuz he wants me to work for him for free to pay it off. But maybe he'd be able to get me the water pump, thermostat, and hoses.
My fan shroud is busted a little, but has been that way for years. Probably wouldn't hurt to get a new one that isn't glued together in 4 places.
One big plus, I'll be getting my heater core flushed in the process. This was the year my heater started to suck.
I'd really hate to get a new motor and have less power than I do now. This has been my experience with every engine I've ever replaced.
D3<!L!>3D
S8NNG8 is offline
post #1017 of 2977 Old 12-08-2013, 12:09 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Would the AC condenser in front of the radiator have anything to do with the performance of the cooling system?
I don't mean it's location, I mean does it run inline with the coooling system?
D3<!L!>3D
S8NNG8 is offline
post #1018 of 2977 Old 12-09-2013, 04:32 PM
DNFJ
Condenser has nothing to do with the engine cooling system.
Previous:
DNFJ is offline
post #1019 of 2977 Old 12-09-2013, 04:42 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I was thinking that'd be the answer I got, but thank you for verifying that. It's now at the radiator shop getting surgery done.
D3<!L!>3D
S8NNG8 is offline
post #1020 of 2977 Old 12-09-2013, 09:06 PM
8pitcher
8pitcher's Avatar
I have a 4.0 for sale. Just Needs a new main bearing
8pitcher is offline
