Devil liveD: Building S8NNG8 - Page 12 - JeepForum.com
 7Likes
post #166 of 2954 Old 03-30-2013, 06:38 PM
Luke95
Originally Posted by S8NNG8
You got a 'manche, right.
Nope 98 Xj
Sent from my black box
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #167 of 2954 Old 03-31-2013, 08:45 AM
DNFJ
Tire carrier bumper.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #168 of 2954 Old 03-31-2013, 10:36 AM
KG8893
Fix my tire carrier bumper.
Sent from the icon of sin.
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #169 of 2954 Old 03-31-2013, 10:53 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Is it a stock one?
D3<!L!>3D
S8NNG8 is offline
post #170 of 2954 Old 03-31-2013, 11:11 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Here's the deal, I don't build things that the aftermarket is full of. I modify mounts, I fix the problems with existing equipment, I fab parts that don't exist.
If the tire rack bumper is stock, fix the body mount on the rear quarter: open the quarter panel from the inside. Bolts, nuts, lock washers, and 2 pieces of 3/16 plate. Sandwich the sheet metal ... I think you get the point, but the internal plate can designed to cover more area than the external plate, thus providing more support. If it squeaks, lube the joints and wrap electrical tape around the tube that locks in the bracket.
D3<!L!>3D
S8NNG8 is offline
post #171 of 2954 Old 03-31-2013, 11:14 AM
DNFJ
Then you aren't really "Kustom" fab.
Previous:
DNFJ is offline
post #172 of 2954 Old 03-31-2013, 11:36 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Only Kustom!
D3<!L!>3D
S8NNG8 is offline
post #173 of 2954 Old 03-31-2013, 11:40 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
A custom bumper or other mod requires you to put the rig in my shop and converse with me on the qualities that will be designed into the unit.
Now, I will feed you all the fixes you can do yourselves
D3<!L!>3D
S8NNG8 is offline
post #174 of 2954 Old 03-31-2013, 12:16 PM
DNFJ
What if I draw up the plans for a rear tire carrier bumper in CAD for you to mock up on your XJ, then ship it to me?
Previous:
DNFJ is offline
post #175 of 2954 Old 03-31-2013, 12:36 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I'm down with that. My aim is to please you, not me. I like your idea, add comments about specific concerns, cosmetic likenesses, and custom ideas.
Be creative! My latest idea: I found an old, rusty iron drag plate off a tractor bucket. Took a wire wheel to it, it's awesome. It's gonna be the bottom of my rear bumper.
D3<!L!>3D
S8NNG8 is offline
post #176 of 2954 Old 03-31-2013, 01:30 PM
KG8893
The mounts are not an issue. I have the bumper mount one. No hinge on the quarter. I'll attach a picture of it. I need a redesigned hinge cause the shims are busted and one of the bolts sheared off. All the Parts are discontinued from chrysler. I was thinking taking a straight tube through it but I don't have the **** to drill a hole that big.
KG8893 is offline
post #177 of 2954 Old 04-01-2013, 09:25 PM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I am going to continue to make a photo diary of this thread. If you like what I make, I'll make copies.
As far as that tire carrier, ditch it! From an outside perspective: It's really stupid looking. Regardless of the fact that it was designed that way, it looks bad.
Some advice: If you put the tire inside, laying on the floor, right above the axle, it'll cause you less drag weight.
D3<!L!>3D
S8NNG8 is offline
post #178 of 2954 Old 04-02-2013, 09:29 AM
KG8893
I like the way it looks to be honest. It's not so bad with the tire on. Plus they are a rare option so I wanted to try and keep it. And regardless I still can build this one to be strong for cheaper than I can buy one for.
KG8893 is offline
post #179 of 2954 Old 04-02-2013, 10:13 AM Thread Starter
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
That's cool, to each his own.
My advice: Go buy the bit you'll need to drill it out. Then you'll have it in your arsenal
D3<!L!>3D
S8NNG8 is offline
post #180 of 2954 Old 04-02-2013, 02:29 PM
KG8893
Its like a 1 1/4 or 1 3/8 bit... do they really even make **** that big? I only have a 1/2 inch chuck drill also...
KG8893 is offline
