DD 3" shocks ... OME, BILSTEIN or FOX 2.0 ??? - JeepForum.com
post #1 of 5 Old 05-12-2014, 03:38 PM Thread Starter
gerardines
1990 XJ Cherokee
The XJ is a dd so it canīt be too hard to ride in the city or too soft in the dunes, I'm getting 3" coil springs, but a bulbar (80lbs) it's going to be install ...
So which shocks should do the right job ?
- OME Nitrocharger Sport for 3"-5" lift
- BILSTEIN 5100 for 3"-5" lift
- FOX 2.0 for 2.5" lift
thanks
1990 Cherokee 4.0 2.5'' lift Fox 2.0 shocks 30*9.5 Maxxis Trepador
gerardines is offline
post #2 of 5 Old 05-12-2014, 04:23 PM
ParkerXJ
Im in the same situation as you, going with bilstein 5100s personally
2001 Jeep Cherokee XJ Limited -3.5" Rubicon Express Super-Ride kit, H4 headlights
ParkerXJ is offline
post #3 of 5 Old 05-12-2014, 04:33 PM
austinaubinoe
Kinda in the same boat too, except with my ol TJ. Decided on the 5100s aswell because of the price. OMEs will be close to $100 more a set. The new OME sport shock just looks kinda cheap to me, and I am pretty sure they are not montubes either.
You find the bilsteins cheaper then about $80?
austinaubinoe is offline
post #4 of 5 Old 05-12-2014, 07:58 PM Thread Starter
gerardines
1990 XJ Cherokee
At least to what I've found (quadratec) the 3 brands and models are almost at the same price ... just $30+- ...
I've always heard the quality ride of the OME are the best ... and years ago I had the yellow bilsteins in the xj, and the ride was kind of hard.
post #5 of 5 Old 05-19-2014, 02:57 PM
slobra300
I was in the same situation not 4 weeks ago.. I ended up going with Fox 2.0's because the Bilstein 5100's were backorder 6 weeks out at that time... Im happy with the set up. They are a little on the stiff side (no comparrison to go off of but just IMO) but the added plus is that it controls body roll so I am not running sway bars now and do not have to mess with discos. They really shine around my area where we have alot of flat bumpy hard packed sand roads and seem to be "loosing up" as I use the jeep more. Kind of hard to explain but they provide a firm feeling but still remain "flexy" in the woods and they soak up the bumps really nice.. Plus the added look factor is worth noting...
slobra300 is offline
