D30 axle end bushings? - JeepForum.com
post #1 of 3 Old 08-17-2011, 07:47 PM Thread Starter
97 XJeep
Are these the right ones? They specify upper control arm but are these the same that the axle end uses? Thanks.
http://www.quadratec.com/products/56015_100.htm
98 TJ: HP D30, D44 w/ Detroit, 4.88s, 3" lift, 35" KM2s, Warn, lots of plans, lots of beers.
97 XJeep is offline
post #2 of 3 Old 08-17-2011, 08:17 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Yes the axle end uses the same bushings as the frame end.
xjfever is offline
post #3 of 3 Old 08-17-2011, 09:06 PM Thread Starter
97 XJeep
Thanks!
97 XJeep is offline
Help I need UCA bushings for the axle end HighDesertXJ XJ Cherokee Technical Forum 8 10-03-2008 11:18 PM
Axle control arm bushings. xjman4life XJ Cherokee Technical Forum 5 04-25-2007 08:47 AM
Upper axle bushings wipedawg XJ Cherokee Technical Forum 10 07-20-2005 03:47 PM
Rear Axle Whine and LCA bushings Alexia XJ Cherokee Technical Forum 12 10-24-2004 07:28 PM
two bushings on the front axle... cladinshadow XJ Cherokee Technical Forum 1 08-05-2002 07:24 AM
