Cylinder Head Replacement - JeepForum.com
post #1 of 5 Old 04-11-2009, 10:46 PM Thread Starter
COLOUXJ
2010 JK Wrangler
i may need to be replacing my 0331 head on my 2000 XJ and i want to avoid it cracking again( i am not sure if it is cracked i am getting it checked this week) and i would like to replace it with a head other than the one that is always cracking is there any alternatives that are still relatively cheap?
COLOUXJ is offline
post #2 of 5 Old 04-12-2009, 10:15 PM Thread Starter
COLOUXJ
2010 JK Wrangler
anybody know of any aftermarket heads that will be on bolt on?
COLOUXJ is offline
post #3 of 5 Old 04-13-2009, 07:17 AM
jeepkid03
Winning
jeepkid03's Avatar
If mine cracks I'm going with Alabama Cylinder Head. It bolts right in and is beefed up to prevent cracking. http://www.alabamacylinderhead.com/p...ail.php?id=109
hope this helps
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #4 of 5 Old 04-13-2009, 07:46 AM Thread Starter
COLOUXJ
2010 JK Wrangler
it does thank you
COLOUXJ is offline
post #5 of 5 Old 04-13-2009, 08:47 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by COLOUXJ View Post
... are there any alternatives that are still relatively cheap?
0331 heads from a 2002 + TJ Wrangler. The cracking problem was solved by 2002.
CJ7-Tim is offline
Cylinder Head replacement Overcranked XJ Cherokee Technical Forum 22 01-28-2010 05:49 AM
4.0L cylinder head replacement...Walkthrough? MikeMcCasland XJ Cherokee Technical Forum 5 06-16-2009 11:42 AM
cylinder head ajstarr2288 XJ Cherokee Technical Forum 1 03-30-2009 11:06 PM
Cylinder head replacement issue ksturgio XJ Cherokee Technical Forum 8 01-03-2009 10:17 PM
Cylinder Head Replacement - Hints and Help ChairKey00 XJ Cherokee Technical Forum 18 03-12-2007 12:49 PM
