Custom Headliner? - JeepForum.com
post #1 of 67 Old 08-06-2012, 06:05 PM Thread Starter
Whizzerbike
Custom Headliner?
My headliner is starting to sag. Been thinking about putting some awesome headliner in. I seen a place that sells Digital Military Camo headliner. The only thing is that they sell it by the yard...
When i measured my specs of the inside its about 86" Length and 46" Width (please correct me if im wrong). So im thinking about 3 yards of headliner...
Would that be enough to do my OHC and visors?
What should I use to apply it to the roof?
Rating on difficulty? 1- easy 5- hard
Thanks yall in advance!
Whizzerbike is offline
post #2 of 67 Old 08-08-2012, 07:07 AM
alexrule123
alexrule123's Avatar
The hardest part of doing the headliner is pulling all the trim off and removing all the foam backing from the board. If I remember correctly I used 4 yards for everything, headliner, visors, and OHC. IMO this job is a 1 in difficulty. Make sure to get headliner glue, I got mine from Oreilly's auto and one can was enough for mine but it was one of the big orange cans.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #3 of 67 Old 08-08-2012, 07:10 AM
zachndorsett
Most definitely pulling off the trim sucks, but its easy work. Taking off of the old foam is easy, i just used a hard brush and scraped it off. As for material, i smoothed my headboard down and laid truck bedliner on it, i plan on removing the carpet and doing the same. It turned out pretty good, but id like to get another headliner and re-do it in a different brand bedliner.
'96 Jeep Cherokee Sport
zachndorsett is offline
post #4 of 67 Old 08-08-2012, 08:39 AM
Motorcharge
The older the XJ the easier the old foam is to remove usually. Vacuum with the brush attachment works well.
Get some CRC spray adhesive and coat both the material and board and let them sit for 5 min or so before putting them together. Let's the glue thicken so it doesn't leave handprints. Most spray adhesive will only last a few months but the CRC is made for it. Best bet for finding it is a dealership parts department.
There's also a few guides on this in the tech section FAQ.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #5 of 67 Old 08-08-2012, 09:58 AM
CRider74
Anybody just paint their headliner after removing the old one?
Smokin' & Jeepin' (Finally!!!)
CRider74 is offline
post #6 of 67 Old 08-08-2012, 10:48 AM
Altimeter
1997 XJ Cherokee
I did. It needs another coat tho, plus gonna redo the headliner.
1997 Sport XJ - DD
Gone:
1990 MJ, 1998 XJ Sport, 1977 CJ5, 1993 ZJ, 2006 TJ
Altimeter is offline
post #7 of 67 Old 08-08-2012, 11:52 AM
CRider74
Excellent, thanks Altimeter! I'm thinking about doing that with spray-in bed-liner, your reply helps alot.
CRider74 is offline
post #8 of 67 Old 08-08-2012, 11:54 AM
zachndorsett
Did mine with 3 coats of duple-color truck bedliner. Rolled it on, turned out pretty good. Would like to take it out and do a couple more coats on it, but its not too bad. Also did the soundbar that way and it turned out great!
post #9 of 67 Old 08-08-2012, 11:56 AM
CRider74
Yeah, I'm planning on painting the soundbar at the same time. Thanks!
CRider74 is offline
post #10 of 67 Old 08-08-2012, 12:41 PM
Cussawago
I used a queen, thicker cotton bed sheet for mine. Dark Grey in color and about 2 cans of Headliner Adhesive at Autozone. That was 3 years ago, still holding up great. And actually looks pretty good.
Cussawago is offline
post #11 of 67 Old 08-08-2012, 06:06 PM Thread Starter
Whizzerbike
I was thinking its gonna be a horrible putting it up.. until i realized i can take the headliner completely out and snap it back in... aint as hard as i thought
post #12 of 67 Old 08-20-2012, 11:32 AM
CRider74
Got the headliner back in this weekend (still have to put some trim & the soundbar back in tonight). Turned out better than expected. 2 coats of acrylic laquer as the base, then a single coat of the spray-in bedliner. Overall, I'm pretty happy with the results:
CRider74 is offline
post #13 of 67 Old 08-20-2012, 09:00 PM
dunitic
I just bought my son a 1999 and the headliner and trim are missing. In Arizona it gets to hot without it. I checked the junk yards and no luck. Anyone know where I can find the board and trim ?
dunitic is offline
post #14 of 67 Old 08-21-2012, 04:43 AM
Motorcharge
Try Team Cherokee. They sell a ton of OEM parts.
|SOLD|
| June 2015 COTM |
post #15 of 67 Old 08-21-2012, 07:50 PM
CherokeeJon
1993 XJ Cherokee
Those of you that are painting your headliner, are you laying down headliner material over the headliner base and then painting on that or just bedlining the base?
CherokeeJon is offline
camo , custom , headliner , military
My first mod...the headliner! N2Fix XJ/MJ Cherokee Non-Technical Forum 34 09-03-2014 07:15 AM
Anyway to do a custom headliner? GettingDirty XJ/MJ Cherokee Non-Technical Forum 13 03-23-2013 04:58 PM
headliner hoerter2158 XJ Cherokee Technical Forum 7 07-22-2010 06:31 PM
$20 Headliner fix marioct XJ Cherokee Technical Forum 5 02-27-2007 07:55 PM
headliner h2rescue XJ Cherokee Technical Forum 3 01-23-2007 05:29 AM
