currie upper control arm question. - JeepForum.com
post #1 of 1 Old 02-12-2012, 11:40 PM Thread Starter
dezertdreaming
so a few weeks ago, i installed a pair of currie upper control arms on my xj and it was going smooth until i reached the axle end. turns out that currie uses 7/16 bolts for their control arms, while the stockers have 10mm bolts. this wasn't a problem for the frame end as i just opened up the holes with a 7/16 bit. the axle bushing side however was a whole other deal. I ended up shaving the "dimples" inside the bushing until the bolt went through which i still think is kinda sketchy. For the people that installed these before, what did you end up doing? i shaved a little too much on one bushing and i want to look for a better alternative besides the weld on currie jj mount.
dezertdreaming is offline
Upper control arm bushing question. xjcowboy01 XJ Cherokee Technical Forum 2 11-01-2010 04:23 PM
question about upper control arms mmaverick88 XJ Cherokee Technical Forum 7 11-26-2008 10:14 PM
Help With Upper Control Arm boozzer XJ Cherokee Technical Forum 4 06-04-2006 11:15 PM
Upper control arm bushing question mh89xj XJ Cherokee Technical Forum 4 06-01-2006 03:05 PM
Upper/Lower Control Arms befor lift question sociald XJ Cherokee Technical Forum 3 04-27-2006 01:03 AM
