crockett's 92 xj build - Page 11 - JeepForum.com
post #151 of 377 Old 10-25-2013, 05:19 AM Thread Starter
crockett07
1992 XJ Cherokee
Originally Posted by Rockdrummer93
Boy that can't ride good! lol
Yea it's a wee bit bumpy lol
crockett07 is offline
post #152 of 377 Old 10-26-2013, 06:15 PM Thread Starter
crockett07
1992 XJ Cherokee
Found the time to do the relocation brackets today. this was a very simple install, just a little time consuming. First thing I did was pull the old shackle off. this was by far the hardest part of the install, I ended up needing a 4ft breaker bar almost the entire time
Next, just cut the old shackle box off. I didn't get any pictures of this, but its very easy, just keep an eye on the fuel hoses on the drivers side.
next just put the box up in its place using the old shackle bolt, and nutstrips. If you don't have nutstrips already, I would advise them. its just 3 more bolts to tie the brackets in.
Next it says to remove to mark the top holes, and remove the brackets. I just removed the old shackle bolt and drilled straight up into the cab with a 1/2 drill bit and went ahead and tightened the tie in plates in. this process will also suck the brackets up as high as they need to be. I feel like you can go ahead and tighten everything down after this. I did have to trim both tie in plates but it was minor and quick
then just hook your shackles up and find the best angle for your needs.
This is what I ended up with and I may do some more fine tuning tomorrow, the shackle seems to be bottoming out on the back side of the bracket. maybe ill more it one more hole back or possibly a new shackle.
like I said, this was a very easy install and it provided zero lift, just like advertised. no experience on the ride or flex so ill update that when I have a proper opinion
post #153 of 377 Old 10-26-2013, 10:02 PM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Looks good. How hard was it to cut the old sheet metal shackle box out? The the cut and fold make it easier?
April 2014 & 2015 COTM
MOBBiN is offline
post #154 of 377 Old 10-27-2013, 07:17 AM Thread Starter
crockett07
1992 XJ Cherokee
Yes the cut n fold makes everything very accessible! The boxes are a little tricky, but just because the tight corners. I only used one 4.5" cutoff wheel and some vice grips to bend the sheet metal until the corners broke
post #155 of 377 Old 10-27-2013, 08:46 AM
MOBBiN
MOBBiN's Avatar
Makes sense. Thanks for your help! I think I'm going to ditch my RC reloes in favor of the hd non lifting one
MOBBiN is offline
post #156 of 377 Old 10-27-2013, 09:38 AM
VegasGT
1988 MJ Comanche
Looks fantastic man, you've sold me on em.
I do believe you will need to run a longer shackle to get the full benefit, stock shackles dont have much "throw" to them.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #157 of 377 Old 10-27-2013, 09:51 AM Thread Starter
crockett07
1992 XJ Cherokee
Im glad I could help persuade the both of you! what shackles are you running right now vegas?
quick update, I rode around on them a little last night and I came out this morning to find a little carnage
I decided to do a little fine tuning by sliding the shackle back by one hole. only problem with that is the very back 2 holes, the hump from the old shackle nut is in the way, so you have to trim it up a little. once again, a very easy cut with the 4.5'' grinder
and here is the finished product.
the ride is phenomenal compared to before! I definitely think I will go to a different shackle, just for the more throw, but with these boxes, shackle swaps and tuning should only take about 30 min. so far im super happy with these
post #158 of 377 Old 10-27-2013, 12:19 PM
Luke95
K1500 shackles will give you an inch and a half of lift and are similar to the jks shackles. Another potion is ranger shackles. I believe that is what Vegas runs
I <3 rockrash
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #159 of 377 Old 10-27-2013, 12:45 PM Thread Starter
crockett07
1992 XJ Cherokee
Originally Posted by Luke95
K1500 shackles will give you an inch and a half of lift and are similar to the jks shackles. Another potion is ranger shackles. I believe that is what Vegas runs I <3 rockrash
I'm not sure if I want an inch and a half of lift, even though maybe that's the answer if I use the top holes of my brackets. I think I read the ranger shackles are .5" lift? Hmm
post #160 of 377 Old 10-27-2013, 01:40 PM
VegasGT
1988 MJ Comanche
Ranger shackles are on my rig, they work out to about .75" lift but thats irrevelant with a relocater setup like this as the shackle lays flatter. Plus youve got a lot of tuneability there.
Heres the Ranger shackle on my rig, u can see tell the extra length in them, ideal for a situation like you are in here.
Weeder1 is also running these on his relo brackets with good results. These can be had brand new for about half what comparable aftermarket shackles cost.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #161 of 377 Old 10-27-2013, 02:10 PM Thread Starter
crockett07
1992 XJ Cherokee
Yea weeder had mentioned them to me, what year ranger can I get those for?
post #162 of 377 Old 10-27-2013, 02:57 PM
VegasGT
1988 MJ Comanche
Yea weeder had mentioned them to me, what rear ranger can I get those for?
I picked mine up for a 2001 4WD Ranger but Rangers, llike XJ's, remained virtually unchanged over the years. Id say most anything from 93 to current would work, I was just at Advance Auto taking measurements on various shackle options and 2001 is the the random year I chose.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #163 of 377 Old 10-27-2013, 03:00 PM Thread Starter
crockett07
1992 XJ Cherokee
Cool, thanks. I'll try to pick some up in the next couple of weeks
post #164 of 377 Old 11-04-2013, 07:04 AM Thread Starter
crockett07
1992 XJ Cherokee
Quick update: I've had he relos on for almost 2 weeks and they're great, It's like night and day difference. I may try and pick up some ranger shackles sometime this week. Also trying to go wheeling this weekend if weeder will sack up and ask his boss to give him a day off!
post #165 of 377 Old 11-04-2013, 11:05 AM
MOBBiN
MOBBiN's Avatar
I recently installed some ranger shackles. Here's a little comparison that might help you.
From left to right. Stock 3.25" eye to eye. Ranger 4.5" eye to eye. And RE 1.5" shackles were 5" eye to eye.
MOBBiN is offline
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
My Build 89 xj 700$ 18 in HS long build :[ DJN00B Jeep Builds 2 01-11-2011 04:49 PM
