Cracked Headers? Reccomendations for a new set. - JeepForum.com
post #1 of 3 Old 03-12-2012, 08:27 PM Thread Starter
CherokeeTamer
1991 XJ Cherokee
So I'm pretty sure my headers are cracked, i realize that this is a common problem for the 4.0. mine are still factory original from 91 and have been welded once. my problem is i cant pass smog for the life of me. you name it, I've replaced it and/or tested it. the only things that haven't been replaced are the headers and fuel injectors.
long story short, what i want to know is what is the best way to check for a leak/cracks? I'm 80% sure they're cracked but i want to know for sure before i order another set.
also, I've been looking around for a replacement. i dont want to spend any more than $250. my top two right now are these. http://www.quadratec.com/products/17604_110X_PG.htm
http://www.quadratec.com/products/17604_102_07.htm
any help/incite is much appreciated.
Thanks!
CherokeeTamer is offline
post #2 of 3 Old 03-13-2012, 12:11 AM
DezertXj88
1990 XJ Cherokee
You could buy the updated stock replacement..Has flex pipes & gussets to prevent cracking..
I bought one for my 88 and it didn't fit, so I have a brand new one sitting in my garage if you want it for cheap...never had heat through it. 90 and its yours with a new gasket.
DezertXj88 is offline
post #3 of 3 Old 03-13-2012, 03:27 PM Thread Starter
CherokeeTamer
1991 XJ Cherokee
i was thinking about a stock replacement at first (theres a cheap one on amazon) but decided to jump on the opportunity to upgrade.
Would Cracked headers trigger O2 codes? banesterloren XJ Cherokee Technical Forum 2 04-03-2011 11:18 PM
Reccomendations? Glantzy XJ Cherokee Technical Forum 12 09-26-2007 09:37 PM
replacing cracked headers rosader XJ Cherokee Technical Forum 1 11-28-2006 05:48 PM
Header Reccomendations? EnderUSAF XJ Cherokee Technical Forum 1 07-31-2006 05:07 PM
Fog light reccomendations Saab XJ Cherokee Technical Forum 11 04-27-2006 04:09 PM
