Cooling upgrades - JeepForum.com
post #1 of 2 Old 05-23-2013, 04:46 PM Thread Starter
dlargo
Cooling upgrades
Afternoon all,
Been lurking for awhile and decided to post for some advice on some cooling upgrades and advice. I have a 2001 XJ (obviously) with the 4.0, Auto, 231 TC, with everything basically stock. In March I installed a 2.5" OME Lift, JCR front bumper, winch, and roof rack with 6 KC lites. All runs well and works as it should. Living in Houston and with Summer knocking on our door I wanted to do some upgrades to the cooling system. The temp sits between 210 and 220 on a daily basis. Within the last couple of days it spiked to 260 for second and then back to normal. I have no leaks and just replaced the coolant with a 50/50 mix of antifreeze/distilled water.
The electric fan is what I am concerned about. I have noticed it will not come at with the AC (as I believe it should) 100% of the time. It is random. How can I go about testing to make sure that it is functional and what kind of upgrades can I do to beef up the cooling system without too much fabbing. I like to keep things as close to stock as possible....or at least the perception of stock.
Thanks
Danny
dlargo is offline
post #2 of 2 Old 05-25-2013, 01:49 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Properly maintained, the XJ cooling system needs no upgrades. Hood vents are a useful modification that helps lower temperatures at slow speeds and on the 4x4 trails.
In about mid 1999 the e-fan was reprogrammed to only run as required by engine temperature. Older Cherokees run the e-fan with the A/C or Defrost. If you unplug the wires from the Coolant Temperature Sensor on the thermostat housing, the e-fan should start up. If it starts, everything is OK.
Overheating can be caused by anything that decreases the cooling system’s ability to absorb, transport, and dissipate heat, such as a low coolant level, loss of coolant (through internal or external leaks), poor heat conductivity inside the engine because of accumulated mineral deposits in the water jackets or radiator, a defective thermostat that doesn’t open, poor airflow through the radiator, a slipping fan clutch, an inoperative electric cooling fan, a collapsed lower radiator hose, an eroded or loose water pump impeller or even a defective radiator cap.
The cooling system is a group of related parts that depend on proper function from each of its component parts to keep the engine cool. Service the cooling system and replace any under-performing or suspected weak parts. Any component part of the cooling system that is not fully doing its job will stress the others and your cooling system will overheat. Temperature creep on the 4x4 trails, at idle, or in stop-n-go traffic points to a weak or failing mechanical fan clutch.
The most important maintenance item is to flush and refill the coolant periodically. Coolant should be replaced every 36,000 miles, or every two to three years. Anti-freeze has a number of additives that are designed to prevent corrosion in the cooling system, but they have a limited life span. The corrosion causes scale that eventually builds up and begins to clog the thin flat tubes in the radiator and heater core, causing the engine to eventually overheat.
-Use a flushing/cleaning solution and then drain and fill the radiator with a fresh 50/50 coolant and water mix. With a neglected cooling system you may have to flush several times.
-Inspect the radiator for mud/bugs/grass clogging the outside and mineral deposits clogging the inside. Clean or replace as needed.
-Replace the thermostat with a STANT or Robertshaw 195* thermostat. Cheap thermostats are cheap for a reason.
-Replace the radiator cap if your Jeep has one. An old worn out radiator cap will allow boil overs and/or allow the coolant flash over into to steam. You will see the coolant temps suddenly jump from 210* to the Red Zone and back to 210* if your radiator cap is weak.
-Inspect/test or replace the mechanical fan clutch. A worn fan clutch will allow temperature creep at stoplights, in heavy traffic, and on the 4x4 trails. A fan clutch that “looks” OK is not the same as working OK.
-Inspect the electric cooling fan and the fan relay. Apply 12 volts and make sure the fan runs. Exchange the cooling fan relay with one of the others similar relays. Confirm that the e-fan starts when engine temps reach 215-218*. Repair or replace the fan or relay as needed.
-Inspect/test or replace the coolant temperature sensor that activates the e-fan.
-Replace the water pump. The pumping fins can deteriorate over time and the pump will not flow enough coolant to keep the temps under control.
-Inspect/replace the radiator hoses. Make sure the coiled wire is installed in the lower hose.
If you have covered all the points listed above and still have overheating issues, inspect and test the head for cracks and head gasket for leaks. Exhaust gasses entering the coolant can raise the temperature of the coolant or cause steam pockets in the coolant that will temporarily block the flow of coolant
Read more about cooling systems here –
www.offroaders.com/tech/engine-overheating.htm
www.familycar.com/classroom/coolingsystem.htm
CJ7-Tim is offline
