converter - JeepForum.com
post #1 of 3 Old 07-22-2008, 07:04 PM Thread Starter
xjpete
1997 XJ Cherokee
converter
Recently my catalytic converter started to smell somewhat bad.Contacted the 4 wheel drive place where i get most of my work done and was told that they can only put the OEM cat back on the vehicle.2 years ago this was not the case.They said it is a $15,000.00 fine if they put on an after market cat.Does this sound right? Also they said the cat goes for $580.00 not including labor.Are my getting fed a line of bull?Please someone.Thank You.Also should i try the O 2 sensor to see if that is fried?Wouldn't that cause the cat to break down.So far no check engine light.Thank God!
xjpete is offline
post #2 of 3 Old 07-22-2008, 07:05 PM
norsky
I would suggest just doing it yourself all you need is an angle grinder and a few wrenches. Magnaflow cat from Summit $115 shipped to your door. My .02
~norsky
White 99 XJ Sport
norsky is offline
post #3 of 3 Old 07-22-2008, 08:04 PM
EagleStorm
2008 WK
you can put on aftermarket cats the problem we have had is some of them wont pass a I M test even though they are new had one 2 mo ago we tryed everything to get it to pass he was told by someone else he needed a eng we recomended a new factory cat he whined for a while bought the new cat and went to the muffler shop that welded there cat in then we retested passed just fine muffler shop gave him back his money
EagleStorm is offline
Mud in a Cat. Converter sAe23 XJ Cherokee Technical Forum 7 11-12-2009 03:21 AM
cat-converter ben83 XJ Cherokee Technical Forum 19 04-07-2009 03:13 PM
torque converter seal leaking=new converter?? iwishihad1 XJ Cherokee Technical Forum 3 01-23-2008 06:38 PM
cat converter dented XJ Cherokee Technical Forum 3 11-22-2006 07:23 PM
Cat-Converter XJ95mlake XJ Cherokee Technical Forum 12 05-18-2006 03:28 PM
