Converted from Range Rover to XJ - Pics - Page 2 - JeepForum.com
post #16 of 32 Old 03-10-2012, 08:35 AM Thread Starter
islandsnow
Originally Posted by rsurran View Post
Welcome aboard. You need to get under the hood and check your fluids. You probably have the dreaded 0331 head (many of us do) which has a tendency to crack when it is overheated. I keep my coolant right at the top line of the Full marker so I can see at a glance if I have lost any. Also mind your oil level and keep them both pristine. Don't go radical over having the 0331 head like wanting to swap it out right away. Your Jeep runs great, that's all you need for starters. The 4W project is worth doing because it will mean you can do more with your Jeep and it will increase the value of it.
Funny you mention that, I had a friend replace my alternator last night and while he was doing it I was checking fluids and saw that the coolant tank was nearly dry but I swore 2 weeks ago it was full. My temp gauge never gets near the middle though, ill watch out for leaks.
Should I trust the oil pressure on the dash? or its better to just check physically once every few days.
Good to know that 167k isn't considered high mileage for this engine.
islandsnow is offline
post #17 of 32 Old 03-10-2012, 01:22 PM
rsurran
I have not had the experience but the most prominent sign of a cracked head is unexplained coolant loss. HOWEVER, you will lose some coolant a little at time through natural causes. If your PO didn't maintain the Jeep your overflow could be nearly dry and you are still ok. A full flush and refill could be in order. Otherwise fill it an keep an eye on it frequently. You Jeep is no doubt not using any oil but I would also pull the dip stick frequently at first to make sure it is clean and full. I change my oil every 3k and it never really gets dirty. As for the type of oil there are volumes of posts on that subject. IMO a good 10W-30 will do the job.
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
post #18 of 32 Old 03-12-2012, 10:20 PM
BlueBadger
It's always good to check the level but that doesn't mean you have good pressure. With as many miles as mine has on it. I too got concerned. I installed a quality mechanical gauge. And pressure was actually higher then the dash said but is lower then should be. The good thing is these 4.0's can operate with little oil pressure for a long time if needed. They are stout power plants. Chrysler really messed up when they killed it off. You won't find anyone that will disagree with that.
BlueBadger is offline
post #19 of 32 Old 03-21-2012, 04:31 PM Thread Starter
islandsnow
Hey guys, how do I know if I have the infinity radio or not. I currently have a cd/tape deck with bass/mid/treb adjustment bars. I'm thinking its just the basic system but I can't find any pictures of either system to tell the difference.
post #20 of 32 Old 03-21-2012, 04:42 PM
Oregon187
Contact Jeep
Use this link to get your build sheet. (You may have to click on this text on the first page the link above takes you to ">> Click Here To Proceed To Link Destination <<" to actually go to the site) That will give you some decent information about what your XJ came with from the factory, which most likely is what is on it now.
2001 XJ build thread --
Oregon187 is offline
post #21 of 32 Old 03-21-2012, 04:54 PM Thread Starter
islandsnow
Just did it, I guess I wait on a email response? I included vin, email and address and put in the comments that I was requesting the build sheet and what came standard.
post #22 of 32 Old 03-21-2012, 04:56 PM
Oregon187
Yup, just wait. I asked for mine just the other day and I had it within a day or so.
post #23 of 32 Old 03-21-2012, 05:21 PM
rsurran
How is the coolant looking, any loss since last week?
Dick Surran
rsurran is offline
post #24 of 32 Old 03-22-2012, 11:06 AM Thread Starter
islandsnow
Thanks for the reminder on the coolant!! I'll check today and let you know.
1 issue did begin though that appears common, my left speaker and window switch intermittently works, windows seems to only go down and up if I have the driver door swung all the way open, if I shut it and press up or down, the lights inside the switch turn off and nothing moves. Guess I have a short.
Another odd thing along with that is that when I turn on the rear defogger, the green lights turn off, on all the windows switches and door lock switches until I turn the rear defogger off.
Looks like I don't have the infinity but ill just post everything in the email below anyway.
Sales Code Description
*M5 Cloth High-Back Bucket Seats
-AZ Agate
AA4 Sport Value Group
ADAP Light Group
APAS Monotone Paint
AWHP Power Equipment Group
AWS Smoker's Group
A20P 4.0L Engine(ERH)/4Sp Auto Trans(DGS
BASS 124 Amp Alternator
BCDS 500 Amp Maintenance Free Battery
BGAS Power Front Disc/Rear Drum Brakes
CADP High Back Bucket Seats
CBWS Highline Door Trim Panel
CDBS Reclining Front Seats
CFMS Rear Folding Seat
CF4S Child Seat Upper Tether Anchorages
CGGS Traveling Inboard Seat Belt Buckle
CGWS Next Generation Front Air Bags**
CKAS Carpets - Floor and Cargo Area
CKNS Cargo Compartment Carpet
CKTS Cargo Tie Down Loops
CKXS Midgate Box Access
CLEP Front & Rear Floor Mats
CSAS Spare Tire Cover
CSRS Passenger Assist Handles
CSSS Illuminated Rear Assist Handles
CUFS Full Length Floor Console
CUXP Front & Rear Ash Trays
DGBS All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHAP Lock-Up Torque Converter
DHSP Floor Mount Automatic Shift Lever
DMDP 3.55 Rear Axle Ratio
DRAS Corporate 8.25 Rear Axle
EAAC All Engines
ERH 4.0L I6 Power Tech Engine
GAL Deep Tint Sunscreen Glass
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEEP Deep Tint Sunscreen Liftgate Glass
GFAS Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNCP Sun Visors w/Illum Vanity Mirrors
GTS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMP Remote Keyless Entry
HAAP Air Conditioning
HGDS Deluxe Insulation Group
I49S Route 49 - CSX Birmingham, AL
JAYS Instrument Cluster w/Tach
JBFS Instrument Panel Black Bezel
JCDS 100 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBP Rear Window Wiper/Washer
JJAP Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
KDPS STRIPE/BADGE/MOLDING COLOR
KGPS STRIPE/BADGE/MOLDING/COLOR
KTPS STRIPE/BADGE/MOLDING/COLOR
KVPS STRIPE/BADGE/MOLDING/COLOR
KYPP STRIPE/BADGE/MOLDING/COLOR
K2ZS STRIPE/BADGE/MOLDING/COLOR
K3LS STRIPE/BADGE/MOLDING/COLOR
LAJS Headlamps On Warning Chimes
LBBP Courtesy Lamps
LCDP Map/Dome Reading Lamps
LDAP Underhood Lamp
LDBP Cargo Compartment Lamp
LHDP Headlamp Off Time Delay
LMAS Halogen Headlamps
LNJ Fog Lamps
LPSS CHMSL Lamp
MBKS Black Front Bumper End Caps
MBLS Body Color Front Bumper
MBSS Black Rear Bumper End Caps
MBTS Body Color Rear Bumper
MCAS Front Bumper Guards
MDA Front License Plate Bracket
MFBS Body Color Headlamp Bezels
MFKS Body Color Grille
MHAS Black Windshield Moldings
MMCS Rear Qtr Solid Window Insert
MMGS Belt Moldings
MMKS Body Color Drip Trough Molding
MNAS Black Door Handles
MNNS Body Color License Plate Brow
MWGP Roof Rack
NAS 50 State Emissions
NBKS EVAP Control System
NBVP Low Emission Vehicle (LEV)
NFAS 20 Gallon Fuel Tank
NHM Speed Control
PS5 Silverstone Metallic Clear Coat
QS5S Silverstone Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RAZ AM/FM Cassette Compact Disc Radio
RCRP 4 Speakers
RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCGP Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SHAS Front Stabilizer Bar
SHCS Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBCS Compact Spare Tire
TBLS Inside Mounted Spare Tire
TRLS P225/75R15 Wrangler RT/S AT Tires
TZAP Goodyear Brand Tires
WJW 15X7.0 Aluminum "Ecco" Wheels
WLZC All Aluminum Wheels
XCYS Delete Remote Start System
XJFS Tethered Fuel Filler Cap
XPFS Protective Coating and Remover
YAAS Build To U.S. Mkt. Specifications
post #25 of 32 Old 03-25-2012, 04:15 PM Thread Starter
islandsnow
Coolant looks good, bottle is still full so far. I'm hoping the previous owner had the head issue and fixed it before i took over.
Currently I'm only getting 200 miles out of a full tank with 70% city and 30%hwy driving. I don't think that's terrible but I could probably grandma the pedal a bit.
post #26 of 32 Old 03-25-2012, 07:17 PM
N8N
Do you have heated mirrors? I bet you have broken wires in the drivers door jamb. Common problem.
N8N is offline
post #27 of 32 Old 03-25-2012, 08:18 PM
Oregon187
Does yours have the closed radiator system without a radiator cap? Mine had the radiator changed by the PO and to an open system, which is nice for really checking the coolant level. I never trust the overflow bottle personally.
200 miles per tank is lower than what I get but I drive the opposite of you with about 75% hwy and 25% city, but mine is lifted 3" and sitting on 31's so your mileage may be a little low but I wouldn't know what to tell you to look for on that subject.
post #28 of 32 Old 03-26-2012, 05:12 AM Thread Starter
islandsnow
Yes I do, and I believe you're right, was at burger king last night and got the window down but couldn't get it back up, I opened the door half way and squeezed the black rubber that hides the wires going to the door and boom it worked.
I have the open system, overflow bottle on left behind battery, and cap on the right, when I refilled about 3 weeks ago I dumped coolant in both areas, I didn't trust just the bottle either.
I'm definitely gonna look into what is going on to improve mileage.
post #29 of 32 Old 03-26-2012, 05:20 AM
mrJ
2002 KJ Liberty
I've got a 242 out of an xj with shafts if you're interested
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #30 of 32 Old 04-02-2012, 09:47 PM Thread Starter
islandsnow
Just took the Jeep on its first road trip last week, racked up 540 miles over the weekend visiting Chattanooga and Nashville, my friend says the suspension is comfy lol.
Gas mileage was nice, averaged 75 to 80mph, Birmingham to Chatty then did some city driving and exploring then to Nashville all on one tank. Nash back to Birmingham only took half a tank, ran a/c the whole way. All the gauges behaved. Roughly 10 hours was spent in the Jeep this weekend, my back feels great and didn't get tired at all.
Got some lottery tickets while I was out there too lol.
I like the stock speakers, think I may add a sub or just aftermarket rear speakers. Since it kills most of the road noise anyway.
Can't wait to take it on my upcoming Miami and Colorado trips this year. Looking at rooftop carriers to add to the rack.
4x4 , pictures , review , xj
I converted my buddy into a XJ fan samuraisavr XJ/MJ Cherokee Non-Technical Forum 6 08-13-2010 12:19 PM
Have I Been Converted To 134a? 88XJSport XJ Cherokee Technical Forum 8 08-21-2008 07:06 PM
Heard this would work: Range Rover conversion danielhays_98xj XJ Cherokee Technical Forum 16 03-27-2008 08:23 AM
Converted my brakes (pics) xjrrrdx XJ Cherokee Technical Forum 60 03-28-2007 10:17 AM
I've Converted Parky XJ Cherokee Technical Forum 15 02-28-2007 05:41 PM
