convereted him to the dark side - Page 3 - JeepForum.com
post #31 of 50 Old 05-29-2013, 04:59 PM
BeauDuke01
1990 XJ Cherokee
and this time i remembered to charge my camera, so maybe some pics out of this deal
BeauDuke01 is offline
post #32 of 50 Old 05-29-2013, 09:11 PM
BeauDuke01
1990 XJ Cherokee
ok this is where i started last night. carpet peeled back and new shifter bolted down
the carpet is disgusting
picked out a spot to put a brand spankin new hole
had to buy a new hole saw cause i cant find any of my old ones, and my MGDWJ only had a 4" hole saw
and its too late to turn back now
ran the cable through my new fresh shiny hole in the tranny tunnel
and let the re assembly begin
all put together and buttoned up
even managed to get some of the dirt out of the carpets
post #33 of 50 Old 05-30-2013, 04:09 PM
Puck81
How did you seal that hole you made?
Puck81 is offline
post #34 of 50 Old 05-30-2013, 07:04 PM
BeauDuke01
1990 XJ Cherokee
factory rubber gromet on the shift cable
post #35 of 50 Old 06-02-2013, 07:28 PM
BeauDuke01
1990 XJ Cherokee
swapped the cps, and pulled the dizzy to re set timing, trying to get my no start issue fixed... much to no avail.
post #36 of 50 Old 07-29-2013, 01:14 PM
BeauDuke01
1990 XJ Cherokee
been renovating the house, so the xj got put on the back burner... but i got to play around i MGWJ's buggy yesterday, so i got the itch back.
gonna try and pick up another distributer and see if mine got screwed up from the PO. `
post #37 of 50 Old 07-31-2013, 01:52 PM Thread Starter
MGDWJ
that thing looks sexy!!!!! i will have to go touch myself now.....
MGDWJ is offline
post #38 of 50 Old 08-04-2013, 01:13 PM
Camfam07
I like your XJ! that is a very great starting point, sometimes can be a pain to figure out everyone elses mistakes/issues, but great rig man!
Camfam07 is offline
post #39 of 50 Old 08-04-2013, 07:22 PM
BeauDuke01
1990 XJ Cherokee
thank you sir, and you aint kiddin neither... some of the things done to this rig really make you just scratch your head and wonder. it could have been so much easier to do things correctly, but i guess its faster to just cobble some bs together and call it good.
post #40 of 50 Old 08-08-2013, 01:46 PM
BeauDuke01
1990 XJ Cherokee
fed ex showed up 5 minutes after i left to go back to work...
post #41 of 50 Old 08-08-2013, 01:47 PM
BeauDuke01
1990 XJ Cherokee
helped MGDWJ load his other ride on a trailer
post #42 of 50 Old 08-10-2013, 10:29 AM
BeauDuke01
1990 XJ Cherokee
Ok guys, I need help... ive put on a new cps, new distributor, and for good measure threw on a new coil as well. It still wont crank, just spins and occasionally backfires through the intake. ive re timed this thing so many times i can do it in my sleep. Fuel pressure is good, and battery has plenty of juice. Since it used to me a manual, is it not starting because of the NSS? I did notice last night that the MAP sensor doesnt have a vac line run to it, but i didnt think that would keep it from starting, just would make it run like ****. Any advice is welcome, as I've run out of ideas, thanks Beau.
post #43 of 50 Old 08-13-2013, 12:49 PM
BeauDuke01
1990 XJ Cherokee
pk, the guys over on cherokeeforum told me that the flywheel is diff from the 90 renix system to the 98 chrysler system... so i need a new flywheel
post #44 of 50 Old 09-06-2013, 12:40 PM
BeauDuke01
1990 XJ Cherokee
ok, so MGDWJ came by and hooked me up with a renix flywheel... hopefully in the next couple weeks i can get the motor and tranny split and swap em out
post #45 of 50 Old 09-14-2013, 07:30 PM
BeauDuke01
1990 XJ Cherokee
ok, got the driveshafts off, the bottom two bolts out of the bell housing... and saw that the top two bolts require female torx sockets, so i have to go buy new tools before i can split the engine/tranny
