control arm bad angle?? - JeepForum.com
post #1 of 2 Old 02-10-2012, 04:02 PM Thread Starter
Liberator18
1988 XJ Cherokee
hey jeepforum take a look at my short arms and give me ur input
1 the fist pic is sitting on flat ground
2 the second pic is flexed halfway
3 the third pic is showing how my axle is being pulled back at half flex
when i fully flex the control arm gets to about a 75 degree angle its pretty bad i dont have a pic of it but.....its bad.
drop bracket or long arm obviouslly long arm is way better but expensive. so would a drop bracket fix this problem
thanks.
Liberator18 is offline
post #2 of 2 Old 02-10-2012, 04:06 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by Liberator18 View Post
... would a drop bracket fix this...
Yes. After about 4" of lift control arm drop brackets are beneficial. They will smooth out the bumps on pavement and give you more flex.
CJ7-Tim is offline
RESTING lower control arm angle question ericfx1984 XJ Cherokee Technical Forum 0 07-28-2011 03:56 PM
control arms vs front pinion angle! zte87 XJ Cherokee Technical Forum 52 12-12-2010 10:06 PM
Should my Evaporative Emission Control System Purge Control Valve Circuit constantly themow XJ Cherokee Technical Forum 2 01-26-2010 06:06 PM
Corelation between caster angle and pinion angle firehawk XJ Cherokee Technical Forum 13 04-07-2009 08:16 PM
RE control arm drop brackets and Rusty's ADJ control arms xjmatt XJ Cherokee Technical Forum 4 09-30-2004 04:58 AM
