Considering buying an xj. It has no rear drive shaft though. - JeepForum.com
post #1 of 12 Old 11-02-2010, 12:19 PM Thread Starter
dirtslut97
I'm considering buying an XJ with a 4in lift that has no rear drive-shaft on it because the guy never installed a TC drop or SYE on it. So he took it off since it kept eating through u-joints. If I decide to get it then I am going to have to put it in 4hi and ride home in FWD. This sounds like a bad idea to me, but I was looking for some other opinions. Thanks.
dirtslut97 is offline
post #2 of 12 Old 11-02-2010, 12:38 PM
jslong17
1995 XJ Cherokee
How far do you have to drive? If it isn't terribly far then while not the greatest idea it does get you home.
jslong17 is offline
post #3 of 12 Old 11-02-2010, 01:11 PM
1997_Sport
I have driven home about 20 mins in 4hi before with no rear driveshaft.
1997_Sport is offline
post #4 of 12 Old 11-02-2010, 06:13 PM Thread Starter
dirtslut97
It would be about a 30-45 minute drive back. Is there a certain speed I shouldnt go over?
post #5 of 12 Old 11-02-2010, 06:19 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Legal speed limit and whatever feels comfortable.
cruiser54 is offline
post #6 of 12 Old 11-02-2010, 06:54 PM
1997_Sport
What Abingdon are you in?
post #7 of 12 Old 11-02-2010, 08:14 PM
JunkJeep228
1994 XJ Cherokee
doesn't he have the old shaft? even with bad u joints it'll get u home and only take a couple min to put back in. Driving with front only is no big deal i'd be more worried about whats keepin fluid in the transmission. Have a parts beater we took the rear out of to do front wheel burnouts, little bit of torque steer, but still Jolly good fun.
"Wheel it, Break it, Build it better." Words to live by.
JunkJeep228 is offline
post #8 of 12 Old 11-02-2010, 09:21 PM
1997_Sport
You can always ghetto rig it with a gatorade bottle and some tape and stuff, so that no fluid comes out.
post #9 of 12 Old 11-02-2010, 09:39 PM
klarendonkid
welcome to xj engineering 101. if youre new to this class, begin taking notes...
'98 XJ Sport- The Purple Ox (DD)
'91 XJ Briarwood - The Spruce Moose (part owner, trail rig project)
klarendonkid is offline
post #10 of 12 Old 11-03-2010, 09:26 AM
JimmyDiablo
1987 XJ Cherokee
AAA plus service has free 100 miles of towing, do you or any of your friends have that service?
"Gay, Stupid and Dumb" are not words that apply to inanimate objects, period.
When you deal with adults, expect to be corrected.
JimmyDiablo is offline
post #11 of 12 Old 11-03-2010, 02:10 PM
TJedge
I knew I'd seen your TJ before. We live in the same town. Finally a member near me.
TJedge is offline
post #12 of 12 Old 11-04-2010, 06:59 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
I would be afraid of what you may find in the rear or transfer case there may be a problem and hes trying to pass it off on you.I would grab the rear yoke and give it a good wiggle just to make sure the bearings arent bad and also check to see if the output shaft on the transfer case spins.if so it could be bad angles and driving on front wheels only will be fine I broke my rear drive shaft about 150 miles from home and drove back home with only front wheel drive.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
Buying a SYE - After how high of a lift should I not use a stock xj drive shaft? Element96x XJ Cherokee Technical Forum 2 08-01-2009 09:59 AM
Rear drive shaft help GOKUSXJ XJ Cherokee Technical Forum 20 06-05-2008 09:22 PM
rear drive shaft 1996jeepgirl XJ Cherokee Technical Forum 5 12-30-2007 03:41 PM
Rear drive shaft Help!!! racerdrew XJ Cherokee Technical Forum 10 03-19-2007 02:26 PM
front drive shaft as a rear drive shaft jeepsteads XJ Cherokee Technical Forum 42 12-15-2006 10:09 PM
