Congratulations to our November Cherokee of the Month: Cruzin Illusion
#1 | |
The Post man
Congratulations to Cruzin Illusion for winning Cherokee of the Month for November 2008.
Cruzin Illusion Owner Tom and Rebecca Barger Hometown Commerce City , Colorado Vehicle Type 1987 Jeep Cherokee Pioneer Builder Tom Barger Chassis Frame / Chassis Design Stock Frame / Chassis Materials Stock Cage / Cage Material Cruzin Illusion Customs 10 point Cage / 1.5"x.120 Overall Wheelbase 102 inches Overall Length 168 inches Belly Pan Clearance 25 inches Overall Height 73 inches Wheel Track Width 78 inches Overall Weight 4600 lbs Drivetrain Front Suspension / Type / Materials 8.5" TNT Customs Y-Link with 7" Rubicon Express Extreme Duty Coils Front Sway Bar N/A Front Shocks Sky Jacker Nitro's Front Bump Stops Cruzin Illusion Customs Custom Length Bumpstops Front Axle Housing Cruzin Illusion Customs Shortened Ford HP Dana 44 TNT Custom’s High Pinion Dana 44 Truss Conversion TNT Customs Above Axle Track Bar Conversion Front Differential / Locker ARB Locker Front Ring & Pinion / ratio 5.13 Yukon Reverse Cut Gears Front Differential Cover Riddler Manufacturing Chromoly Differential Cover Front Axle Shafts Alloy USA Custom Length Chromoly Inner Shafts Alloy USA Chromoly Outer Shafts Front U-Joints Yukon Super U-Joints Front Drive Flanges / Hubs Warn Premium Hubs Front Brakes Chevy 1/2 Ton Brakes Front Steering Setup Matt Cooks Drag Link and Tie Rod Parts Mike Parts High Steer Arms C-Rok Sleeved Inner Steering Brace PSC Hydraulic Assist Front Driveshaft Drivetrain Specialties Rear Suspension / Type / Materials Cruzin Illusion Customs 4-Link with Fox Shock Coilovers using Rock Krawler Axle Brackets and TNT's Truss Rear Sway bar N/A Rear Shocks Fox Shock 10" Coilovers Rear Bump Stops N/A Rear Axle Housing Dana 44 Rear Differential / Locker 33 Splined Detroit Locker Rear Ring & Pinion / Ratio 5.13 Yukon Gears Rear Differential Cover Crane Hi-Clearance Differential Cover Rear Axle Shafts 33 Splined Superior Axle Shafts Rear U-Joints N/A Rear Drive Flanges N/A Rear Brakes Cruzin Illusion Customs Ford 8.8 Disc Brake Conversion Rear Driveshaft Drivetrain Specialties Rear Steering Setup N/A Tire Make / Size BF Goodrich Krawlers / 35" x 13.5" x 15 Wheel Make / Size / Bolt Pattern Cruzin Illusion Customs DIY Beadlocks 15X9 5x5.5 3.75" BS Powertrain Engine Make AMC Engine Displacement 4.0 Liter Engine TQ 220 ft lb @ 4000RPM Engine HP 177 HP @ 4750 RPM Engine Induction Engine Modifications N/A Batteries Blue Top Optima Radiator / Fans Performance Radiator 2 Core MAC’s Radiator Close System Aluminum Coolant Bottle Air Intake Cruzin Illusion Customs Air Intake K&N Air Filter Exhaust Custom 2.5 Inch Exhaust Transmission Make AW4 - 4 speed automatic, electronically controlled - manufactured by Aisin Transmission Adapters N/A Transmission Cooling System B&M model #70268 Transmission Cooler Kit Torque Converter Stock Transmission Shifter Automatic Transfer Case(s) NP242 Transfercase 2.72:1 ratio low range Tom Wood’s SYE Fuel Containment Stock Body / Interior Body / Body Panels Cruzin Illusion Customs Tube Doors Body Modifications Cruzin Illusion Customs Tube Fenders - Quarter Guards Cruzin Illusion Custom’s Door Pin Off Conversion Cruzin Illusion Custom’s Frame Rail Reinforcements Rear Quarter Panels Cut and Folded Modification Skid plate / Material TNT Customs HD Belly Pan with Transfercase Skid Cruzin Illusion Customs Rock Sliders Painter Name Mike Sweet Hood / Grille Cruzin Illusion Customs CJ Grille Floors / Firewalls Stock Dash / Gauges / Switches Stock / Autometer Water Temp Guage / Standard Switches Steering Column / Wheel Stock / Grant Pedal Assembly / Cutting Brakes N/A Seats / Harnesses Master Craft Rubicon Seats MasterCraft 5 Point Racing Harnesses for Front Seats MasterCraft 4 Point Racing Harnesses for Rear Seat Electronics Cruzin Illusion Customs Manual 4 Low 2nd Gear Switch Modification Lights Interior / Exterior Roundeyes.com H4 Headlights LED Tail Lights Rear Safety - Fire Extinguisher Standard Fire Extinguisher Winches - Front / Rear Warn M8000 with Master Pull Synthetic Rope Extras 10lb. CO2 Air Tank Rigidco Front Bumper with Boxed in Frame Supports Rigidco Rear Bumper with Tire Carrier ![]() ![]() Click here to see previous Cherokee of the Month winners
#2 |
Round Eyed XJ
I just wanted to say thanks for the votes. Everyone entered had really nice XJ's and was deserving to be entered for XJ of the Month.
Gravedigger it was nice to meet you and be able to wheel with you in Moab for the 25th Anniversary of the XJ. Here are a few more pictures of the Jeep: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
CRUZIN ILLUSION BUILT NOT BOUGHT By Cruzin Illusion Customs View the Cruzin Illusion Rig here: View Cruzin Illusion's Rig (OlllllllllllllO) Rock Frog CIC's Build Threads: XJ Bolt on Tube Fenders / XJ-8 Grille (Round Headlight Grille) / THOR 4x4 Quarter Guard Install / XJ Custom Bumper with Swing Down TIre Carrier / Custom Width HP44 Build and Tech /Cruzin Illusions XJ Roll Cage Pics / Cruzin Illusion Tube Door Build |
#3 |
Round Eyed XJ
CRUZIN ILLUSION BUILT NOT BOUGHT By Cruzin Illusion Customs View the Cruzin Illusion Rig here: View Cruzin Illusion's Rig (OlllllllllllllO) Rock Frog CIC's Build Threads: XJ Bolt on Tube Fenders / XJ-8 Grille (Round Headlight Grille) / THOR 4x4 Quarter Guard Install / XJ Custom Bumper with Swing Down TIre Carrier / Custom Width HP44 Build and Tech /Cruzin Illusions XJ Roll Cage Pics / Cruzin Illusion Tube Door Build Last edited by Cruzin Illusion; 11-02-2008 at 09:27 AM.. |
#4 |
very nice, very nice congrats.
-Morgan '00 Silverstone 2 Door XJ Utah Jeep Crew Member #119 My Webshots New Build Old Build |
#5 |
Your tube fenders are awesome! Did you fab them your self? Ive never seen a set like that on a XJ. Nice rig! Congrats
2000 Jeep XJ Sport Lifted on 31s Freedom Edition 1997 TJ 2.5 Low Output SOLD! |
#6 |
Round Eyed XJ
I did build them and there is a complete built write up on them. The link to the build is in my signature. And thank for the comments.
#7 |
One of my favorite xj's, great looking rig and way to be different. Also great write-ups, grats
#8 |
nice Tom. You deserved the win
![]() Hope we can wheel with you again |
#9 |
Grats. Thats a nice XJ
RC 4.5" with ADJ. Trac Bar 33" Pro Comp Xtreme M/T on Cragar Soft 8's FlowMaster HD Super 44 with Dual Turndowns 2 12" Alpine Type R's - 2600W Amp |
#10 |
Congrats dude I totally like your front grille looks awesome and unique
#11 |
One of my favorite rigs on here. A real eye-catcher. Good job!
#12 |
Congrats Tom!
I'm surprised you haven't won this honor before now. |
#13 |
i've seen his rig before and have always thought it was the most beautiful xj ever. that thing is so sweet. congrats mate.
--Turner-- 2006 Jeep TJ 1982 Toyota Pickup 20r/22r Hybrid, 5.29s, Lockrite frt/spool rear, Longfields, Hysteer, discs, armor, dents, smiles. 1970 Ford Bronco302, dana 30, 9", 3 on the tree, show stopper. |
#14 | |
The Post man
Cruzin Illusion
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#15 |
Well deserved. Great XJ
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
