Quantcast Congratulations to our June Cherokee of the Month: Sierra Drifter - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > Congratulations to our June Cherokee of the Month: Sierra Drifter
Old 06-01-2008, 06:49 PM   #1
EricsXJ
The Post man
EricsXJ's Avatar
Congrats to Sierra Drifter for winning the Cherokee of the Month for June!
Sierra Drifter
2001 Jeep Cherokee Sport - Patriot Blue
4.0L Inline 6 HO
AW4 Auto transmission
RocTrac NV241OR 4:1 transfer case from an 04 TJ Rubicon
Tom Woods rear CV drive shaft
Front Axle:
Dana 44 high pinion full width 8 lug from a 1978 Ford F250 68” wide
4340 chromolly alloy inner and outer shafts
Yukon super ujoints
ARB selectable locker
Yukon 5.13 ring and pinion gears
Warn Premium Locking Hubs
Ford 1-ton dual piston disc brakes
JKS over axle trackbar relocation bracket
Custom made sway bar brackets located above the high-steer tie rod
JKS Quick Disconnects
Rear Axle:
Dana 60 full width from 1979 Ford F250 66” wide
Bored spindles to accommodate 1.5” shafts
Yukon alloy 1.5 inch 35 spline alloy shafts
Disc brake conversion using Cadillac Eldorado calipers
JKS shock mounts
Lift:
Rubicon Express 5.5” Extreme Duty suspension lift
T&T Customs Y-Link Long Arm upgrade kit
JKS Adjustable Coil Over Spacers (ACOS) set to minimum height
Two-inch lift shackle on rear leafs
About 7+ inch total lift and a lot of fender trimming
Steering:
Ford flattop knuckles
Harsh Terrain high steer arms
Foothill Offroad heavy-duty tie rod and draglink.
Chevy 1-ton tie rod ends
Waggoneer pitman arm
C-Rock steering box inner and outer reinforcing plates
Steering box brace
Protection:
Custom 4x4 front winch bumper with brush guard and recovery points
Kevin’s double square tube Rock Sliderz
T&T Customs full belly skid
Stock XJ gas tank skid
Custom made differential guards
Plated lower control arm mounts
Other Misc:
37" x 12.50 x 17 Goodyear MTR's
Cragar black steel wheels
Bushwhacker fender flares
Rubicon Express heavy-duty track bar, drop-bracket, and brace
T&T Customs Frame stiffeners
Warn M8000 winch
Lokar cut-to-fit emergency brake cables
Extended stainless steel brake lines
Thule roof rack gutter-mounts and crossbars
Yakima Load Warrior roof rack with extension
Cobra 29wxst CB
Firestick 4ft CB antenna
ARB Air compressor for lockers
Viair 400 Air compressor for tires
Off road lights
Red Top battery
Cut and folded rear quarter panels
Custom made switch box for ARB lockers
Custom made IPod dash mount
4 new JBL Speakers
Two fire extinguishers mounted inside
Highlift jack, tow strap, tree saver, snatch block, d-rings, cable weight etc.
I’ve done every modification myself except the ring & pinion setup, and welding on the front axle brackets. I do my own welding now. After 4 years of modifying I am almost done, well as done as any rig can be. My XJ has been through some of the toughest trails in the west, including the Rubicon, Fordyce, Dusy, Swamp, and two trips to Moab. It has performed well, a couple very minor trail breaks but it has always brought me back home.
Click here to see previous Cherokee of the Month winners
EricsXJ is offline   Reply With Quote
Old 06-01-2008, 07:13 PM   #2
paulthejeeper
Congrats!!! Definately a contender for "Best of the Year!!!
Yeah I take it offroad...my scratches have scratches!!!
[SIZE="2"][/SIZE]03 [COLOR="Silver"]BRIGHT SILVER METALLIC,[/COLOR]TJ,
4.0, auto,
4" rough country lift,
33" baja claws,
black 15" crawler rims,
more mods as budget allows...
[SIZE="5"]J[SIZE="2"]UST [SIZE="5"]E[SIZE="2"]MPTY [SIZE="5"]E[SIZE="2"]VERY [SIZE="5"]P[SIZE="2"]OCKET[/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE]
[U][COLOR="Blue"]USN JEEP CLUB MEMBER HULL#61[/COLOR][/U]
[COLOR="Silver"][U]BRIGHT SILVER METALLIC JEEP CLUB MEMBER #61[/U][/COLOR]
paulthejeeper is offline   Reply With Quote
Old 06-01-2008, 09:46 PM   #3
Sierra Drifter
Just wanted to say thanks to everyone that participated in the COTM.
All the entries were very nice, each one a unique one-of-a-kind XJ,
and all of them deserving of COTM. So congratulations to all of us.
It doesn't matter if you're running a budget boost and 31's or building a monster on 40's,
we are all crazy about our Cherokees. I've owned a lot of vehicles over the years, but I have
never modified one to extent I have my XJ, and I've never been so attached to any of them.
I own a nice daily driver, but I wouldn't care much if something happened to it, but if something
happened to my Cherokee id have to open a vein or something.
Thanks again everyone, I feel very lucky, happy, and honored to be this months COTM.
2001 XJ RE 5.5 ED w/T&T Y-link longarm, 37" MTR's, D44/D60, ARB's, Rubicon Tcase, and all the usual junk.
Axle swaps & build thread: http://www.jeepforum.com/forum/f11/rebuilding-front-dana-44-a-397243/
Sierra Drifter is offline   Reply With Quote
Old 06-01-2008, 09:48 PM   #4
99XJburton
Congrats man, well deserved
NOVA JEEPERS
99XJburton is offline   Reply With Quote
Old 06-01-2008, 10:15 PM   #5
EricsXJ
The Post man
EricsXJ's Avatar
One of the jeeps I look up to.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
Old 06-01-2008, 10:28 PM   #6
ReconMill
Yes Man!
ReconMill's Avatar
2005
x2, love your work. Well deserved!
Kyle - I mod stuff®
SOLD!!! - 1999 XJ Build Thread
ReconMill is offline   Reply With Quote
Old 06-01-2008, 10:54 PM   #7
XJ2000
Congrats, I agree with Eric!
North Jersey Jeep Club
Trail Rig: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline   Reply With Quote
Old 06-01-2008, 11:03 PM   #8
4pointOH1998
I can only dream that mine will look like that some day. Congrats man
-Bryan- ΚΔΦ-MΘΣΝΔ
Fighting the rust since April '08...
A Maine XJ Nightcrew!
4pointOH1998 is offline   Reply With Quote
Old 06-02-2008, 12:02 AM   #9
FrankZ
1997 XJ Cherokee
Congrats!
Spec's
FrankZ is offline   Reply With Quote
Old 06-02-2008, 07:49 PM   #10
_Trucker
'Bigger Member'
_Trucker's Avatar
2002
Congrats sierra!
Thom
NAXJA member # 3388
Originally Posted by BRad704
Hey Lady, relax...Let's not turn this rape into a murder.
_Trucker is offline   Reply With Quote
Old 06-02-2008, 10:39 PM   #11
EricsXJ
The Post man
EricsXJ's Avatar
Originally Posted by trucker1 View Post
Congrats sierra,and I bought your book,can't wait till it gets here!
Sierra, is there something you've neglected to tell me... all these years.... I feel betrayed.
Eric
Old 06-02-2008, 10:44 PM   #12
justinwalden
kudos dude. very impressive build!
Tennessee, Tennessee, There ain't no place I'd rather be!
justinwalden is offline   Reply With Quote
Old 06-03-2008, 09:47 AM   #13
_Trucker
'Bigger Member'
_Trucker's Avatar
2002
Dude i bought your Book,I'm so sorry,in my haste I got you and sierra mixed up.I'm so SORRY!
Thom
NAXJA member # 3388
Old 06-06-2008, 09:30 PM   #14
aircruiser
Moparrrrrrrr
aircruiser's Avatar
Originally Posted by Sierra Drifter View Post
i see youve taken your camera with you mudding too? (black dots in the sky)
yeah i asked one of the dudes at the camera place why i got those black dots and they said it looked like dirt permanently etched into the lens.
awesome rig and congrats!
-2001 Dodge Dakota Quad Cab 4x4 - 4.7 V8, the new hotness!
-1997 Jeep Grand Cherokee Limited - 4.0, 4" lift, 33s, bilstiens, IRO stuff, FOR SALE
-1999 Jeep Cherokee Sport 2 door - 4.0, 8" lift, 35" KM2s, IRO stuff, Long Armed, Armored, Rolled, Parted
aircruiser is offline   Reply With Quote
Old 07-18-2008, 09:20 AM   #15
eflores
1989 XJ Cherokee
your xj looks awesome .....very well build and very cleanly done. best ive seen
AEKDB
Leaky sunroofed XJ member #1
The United States of America July 4, 1776 - November 4, 2008 RIP
eflores is offline   Reply With Quote
Glock Forum
