Quantcast Congratulations to our August 2009 Cherokee of the Month: Sprintagogo - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > Congratulations to our August 2009 Cherokee of the Month: Sprintagogo
Brand new! XJ Rear DIY Bumper from JcrOffroad!Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 08-01-2009, 10:16 PM   #1
EricsXJ
The Post man
EricsXJ's Avatar
Congratulations to Sprintagogo for winning Cherokee of the Month for August 2009.
Sprintagogo
I’m back again for a second attempt at Cherokee of the Month after the little trick EricsXJ played in the April poll.
This is my 2000 XJ which I have owned for a bit over two years. It’s my first Jeep and follows a few Landrover Defenders, but I had to get something with proper seats for the kids. This was the cheap choice that turned out to be every bit as good as a kitted Defender. When I bought it it was badly in need of some intensive maintenance. Jeep have only had an official Presence here in Great Britain since 1993 so used examples only really started to hit the enthusiast scene at the end of the 90’s which means the supply of aftermarket kit and accessories is still limited even now compared to the US. I have done plenty of modifications and here is a summary -
Base vehicle
Cherokee Classic 2000 model year
4ltr I6 with AW4 auto and NP242 transfer case
Black with camel/beige leather interior
124,000 miles
Axles & Driveline
Tires 32.3” tall Insa Turbo Special Tracks (235/85/16 remould) on ZJ/Grand alloy wheels
Front high pinion Dana 30 4.10 ratio which replaces 3.55 ratio low pinion axle
Rear 29 spline Chrysler 8.25 4.10 ratio which replaces Dana 35 with 3.55 ratio and ABS
Trac-lok limited slip diff fitted in place of open carrier
KJ/Liberty rear disc brakes conversion
Rubicon Express 1807 Hack & Tap with front driveshaft
All breather tubes extended
Suspension
4” front lift with 2” Procomp spring and 2” poly spacer
Rubicon Express control arm drop brackets
Skyjacker fixed lower control arms re-tubed with heavier box section
Relocated front brake flexy pipes
5” rear lift with 3” custom built spring, +1” extended shackle and 1” angle block
YJ rear brake flexy pipe
Procomp ES9000 shocks
Protection/Armor
Mopar steering, T-case and tank skids from 1995 XJ
Roof ‘rack’ consisting of gutter slider bars for leaning against trees
Box section rockers welded in place of the original rockers with points for hi-lift jacking
Safarigard snorkel
Recovery
Warn 9.5XP winch with synthetic rope mounted in home made bumper. Transmission oil cooler raised so winch can sit within 1/8” of front crossmember
Tow loops x2 in front bumper and x1 bolted to factory rear hitch mount
fibreglass waffle bridging mats mounted on roofrack
Elecrics
Optima yellowtop battery
Dash mounted winch controls and plug for wander lead so winch can be used from drivers seat or outside the vehicle
Roof lights 8 x 55watts, 4 x spot light for distance and 4 x fog light for spread
CB radio for trail talk
Nokia hands free phone kit
Pioneer 4x50w CD/MP3 player
Quite proud of the truck I have built and had to fab many bits myself due to limited choice and availability on this side of the pond. Also, all the work I have done has had to account for the fact that my wife drives this truck to work and back everyday so had to maintain some civility for her sake. I couldn’t go for an out and out trail rig.
Click here to see previous Cherokee of the Month winners
EricsXJ is offline   Reply With Quote
Old 08-01-2009, 11:18 PM   #2
ajxj9197
1997 XJ Cherokee
goodjob! way to win one from over across the pond!
The wise man sees in the misfortune of others what he should avoid.
ajxj9197 is offline   Reply With Quote
Old 08-02-2009, 04:05 AM   #3
Jones
Infowars.com
Jones's Avatar
Nice rig. I love the lights on the roof.
What is it about Ron Paul?
Jones is offline   Reply With Quote
Old 08-02-2009, 07:06 AM   #4
cornbrizzle
1992 XJ Cherokee
CONGRATULATIONS !!! well deserved
You had gotten my vote I have used some of your responces to work on my junk in the past .
Thank You !!!
Brizzle
cornbrizzle is offline   Reply With Quote
Old 08-02-2009, 10:35 AM   #5
sprintagogo
Thanks guys and everyone else that supported me. I have used huge amounts of knowledge gained through reading this forum so it is only fair that I use my experience of my jeep to give a little back. I don't always do what others do hence little things like the roof lights. Most people go for 2 or 4 big lights while I think anything too obtrusive is just going to get knocked off so chose something with a lower profile.
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline   Reply With Quote
Old 08-02-2009, 08:52 PM   #6
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
congrats mate
they may as well rename it "lancs. xj of the month"...
again well done, you had my vote.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is online now   Reply With Quote
Old 08-03-2009, 01:29 AM   #7
broncofire75
Grats man!
Glad I didnt enter this month LOL. You ran away with it the second time around! Good job on the rig.
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline   Reply With Quote
Old 08-03-2009, 02:28 PM   #8
riptide
Well deserved!
riptide is offline   Reply With Quote
Old 08-05-2009, 05:24 PM   #9
Vassago
The Bike Guru
Vassago's Avatar
congrats dude! good job this time around!
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD: http://www.jeepforum.com/forum/f22/build-thread-year-later-01-xj-643365/
My Photography Paul Lehr's Flickr
Vassago is offline   Reply With Quote
Old 08-06-2009, 09:15 AM   #10
sprintagogo
Yeah..... The Brits are coming!
Rollin on 32'zzzz
Who's eric?
Old 08-06-2009, 08:28 PM   #11
leftlanetruckin
XJ on 37's
and some of us have arrived already mate....
martin
http://www.jeepforum.com/forum/showthread.php?t=324622
Choose wisely!
Old 08-08-2009, 12:41 PM   #12
UKJeepThang
Well done mate!!!
YES......the Brits are coming. Once I've completed all my latest mods I'll be snapping a few "action" pics and sticking mine in a future poll!!
1998 XJ
RE 4.5 inch superflex lift, RE GEN2 disconnects, 15x8 Crager 352's, 33x12.5x15 BFG MT, ARB Lockers Front and Rear, 4.56 Diffs, Cut & Tap Short Shaft Conversion, CV Rear Prop, B&M Transmission Cooler and Gauge, Bushwackers Cut-Outs, Skid Row Armor, AJ's SuperRails, LeBaron Hood Vents, KargoMaster Rack, Safari Snorkel, KC Daylighters, Midland CB, Brantz Navigation
Loads a mud!!
UKJeepThang is offline   Reply With Quote
Old 08-09-2009, 08:16 AM   #13
sprintagogo
Originally Posted by UKJeepThang View Post
Well done mate!!!
It's a good plan Nigel, how are the improvements going?
I wasn't sure that you hadn't entered or won the COTM before but you will definitely get my vote
Let's keep the Brit theme going.
Rollin on 32'zzzz
Who's eric?
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
