Coil sprung conversion for the rear? - JeepForum.com
post #1 of 11 Old 07-11-2008, 01:31 PM Thread Starter
ProMod1385
Has anyone seen a coil spring conversion done on an XJ? I live about 6 blocks from OffRoadOnly and was checking out there AirRock kit the other day. It is so sweet and i am thinking about doing a coil spring conversion to the back of my XJ so i can run the AirRock kit. I am just brain storming here and wanted to know if anyone could recommend a website to start from.
ProMod1385 is offline
post #2 of 11 Old 07-11-2008, 01:46 PM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
http://www.claytonoffroad.com/
go to products > hard-arm suspensions > jeep cherokee
'98 xj sport (trail toy) |
'98 xj classic (dd'er) |
'89 mj tinker toy |
FitchVA is offline
post #3 of 11 Old 07-11-2008, 03:11 PM Thread Starter
ProMod1385
I prowled around on there a bit, cant really find any good pics on there site. For $1500 i am thinking i can fab up my own for a lot less. Do you have an experience with these guys? Are the kits solid and built strong?
post #4 of 11 Old 07-11-2008, 08:50 PM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
http://www.jeepforum.com/forum/showp...3&postcount=16
i believe wil badger ran the setup for a while.
i know a few guys running clayton's front long arm setup. they beat the pee-pee out of it and it stands up
'89 mj tinker toy |
FitchVA is offline
post #5 of 11 Old 07-11-2008, 10:49 PM
wil badger
NO I did not run Claytons.Not that I have anything against their kit.From what I have seen they build a very rugged and well built kit.I have never really heard any complaints about their kits.
That being said I fabricated my rear suspension from scratch and I was running coil overs.
Here are pictures of when the 4 link was built
wil badger is offline
post #6 of 11 Old 07-12-2008, 10:57 AM Thread Starter
ProMod1385
Wow! Your set up seems to work great! Do you drive it on the street much? I tend to drive my XJ to work during the summer on rainy days (otherwise i ride my moto, and i have a beater for the winter).
Like i stated i cant really get a good look at the Claytons set up but i really feel for $1500 i can build a set up similar to yours, even if i had to hire some of the more specialized welding out. What size tires are you running? Would you do anything different if you did it again?
post #7 of 11 Old 07-12-2008, 10:56 PM
wil badger
Well first I'll say good luck on doing a rear 4 link for under 2 grand.Especially if you can not weld or fabricate anything on your own.There is a lot more to it then just putting some steel under the vehicle.
Now as to my rig.Yes I did drive it on the street from time to time.It was mainly a trail only rig but was still registered and street legal.I ran 36" tires on the setup I had and it worked very well.If I had to do it again the only thing that would change is the location of the uppers to give it better separation at the frame side.
post #8 of 11 Old 07-13-2008, 02:01 AM
winkosmosis
Wow.. $1500 isn't that bad considering how much other things cost. Those guys doing the JK axle conversion should just spring for that while they're at it.
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #9 of 11 Old 07-14-2008, 07:35 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
Originally Posted by wil badger View Post
NO I did not run Claytons.[/url]
oops. my bad
'89 mj tinker toy |
FitchVA is offline
post #10 of 11 Old 07-14-2008, 09:07 AM
wil badger
Its all good
post #11 of 11 Old 07-15-2008, 08:47 AM
dcorn
Wow, that Clayton setup is pretty nice, as is yours, Wil.
2014 Jeep Grand Cherokee Summit
dcorn is offline
Rear coil conversion?... Bryson XJ Cherokee Technical Forum 11 12-30-2007 01:31 PM
whos done a rear coil over conversion on their XJ? laurxj XJ Cherokee Technical Forum 4 10-24-2007 12:06 PM
Rear coil conversion WhiteKee XJ Cherokee Technical Forum 7 11-23-2005 05:47 PM
Clayton rear coil conversion... Joe S. XJ Cherokee Technical Forum 9 10-21-2005 08:28 PM
Coil Over Rear Suspension Conversion ATX XJ XJ Cherokee Technical Forum 9 04-20-2005 10:51 PM
