Clunking at rear - JeepForum.com
post #1 of 4 Old 08-24-2008, 08:57 AM Thread Starter
barkerr
Clunking at rear
I recently bought a 2000 Cherokee Sport 4x4. I disposed of a 94 Ford explorer that had nice wheels and new tires. I moved the rims and tires over to the Jeep and started to hear a clunk in the rear on braking. I thought I had jostled the drum brakes in the process and this caused the problem. Inspected the drums and they were due for replacement so I replaced drums, shoes, and hardware on both rear wheels. Took it for a spin and there's the clunk again. Is it possible that the wheels I put on are the problem? The rims are thicker than the factory Jeep rims and the Jeep wheel studs are 1/2" shorter than ideal. Lug nuts do not get quite as much purchase on the studs as I would like. Any thoughts would be appreciated.
barkerr is offline
post #2 of 4 Old 08-24-2008, 11:43 AM
dz1087
dz1087's Avatar
Could be slip yoke. That thing needs to be greased occasionally or you will get a rear-end clunk.
Air Force Jeep Club - Tail# JF037AD
'03 TJ Sport, Black on White, Stock. [[Gone]]
'99 XJ, Purple, Stock but with new wheels.
Running Doorless? Check your state's Mirror Laws!!
There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else.
Theodore Roosevelt
dz1087 is offline
post #3 of 4 Old 08-24-2008, 04:19 PM
srmitchell
I've had a few clunking issues. All solved.
-Wheels, goodyear didn't tighten the lug nuts properly, It made a noticeable clunking sound on release of the brake, etc.
-Slip yoke, needed to be greased.
-Leaf spring bushings, the metal sleeve was wallowed out, so I replaced them. (The whole leafs.)
-Loose u bolts, groaned and clunked.
I work on Mopars
srmitchell is offline
post #4 of 4 Old 08-24-2008, 05:37 PM
JeepRide
JeepRide's Avatar
Had rear end clunk greased the t\case out put shaft driveshaft yoke no more clunk in my junk.
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
Rear clunking? ddoffroad XJ Cherokee Technical Forum 5 12-22-2009 02:53 PM
clunking noise in the rear Deezelweazel XJ Cherokee Technical Forum 2 10-23-2009 04:17 PM
Rear end clunking ghost_rider_x XJ Cherokee Technical Forum 5 11-22-2005 11:42 AM
Clunking sound from rear end JeepRide99 XJ Cherokee Technical Forum 26 08-25-2004 08:50 PM
Rear Clunking.... ddoffroad XJ Cherokee Technical Forum 8 11-04-2002 02:03 AM
