clear corner markers - JeepForum.com
post #1 of 3 Old 07-23-2008, 09:14 AM Thread Starter
boondocksaint
boondocksaint's Avatar
1995 XJ Cherokee
Location: school - Campbellsville, KY; home - Oviedo, FL
Hey folks i'm gettin the clear corner markers for the heep, and i was wonderin if any yall know if i'm allowed to have white lights in 'em, or if i have to keep amber bulbs.
I've heard a couple times that they have to be amber, and i've also heard it's ok to have white....
any help would be appreciated.
Thanks.
David
White 95 XJ - Jacked up and abused
White 98 XJ - Stock and babied
boondocksaint is offline
post #2 of 3 Old 07-23-2008, 09:52 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
they're state laws covering that. so it's best to look them up for your state.
however, while searching for info on my state (va) before i bought and installed them on my dd'er, va requires them to project amber light. so i can use bulbs that aren't amber but still emit amber light. the trouble with amber bulbs is that when daylight hits them, the reflective backing of the clear housing reflects the sunlight going though the bulb causing what people call the egg yoke effect.
they make some expensive silver bulbs but i found a writeup on a BMW forum on how a guy made a DIY version of the silver bulbs.
here's what i ended up with:
the writeup i found did it a little different. he was masking off 3 triangles on the sides of the bulbs and laying down heavy coats of enamel down. then when he removed the tape, he would have amber triangles on the side. i'm not sure how well they work in the shape of a BMW's turn signal housings, but because ours are more flat, the light output flat out sucked. so i chose to do a very light coat of enamel. this diffuses the sunlight shining through them, but doesn't block as much of the amber light when they're in use.
here's a link to my full writeup:
http://fitchva.com/jeep/?p=55
'98 xj sport (trail toy) |
'98 xj classic (dd'er) |
'89 mj tinker toy |
FitchVA is offline
post #3 of 3 Old 07-23-2008, 10:01 AM Thread Starter
boondocksaint
1995 XJ Cherokee
Awesome. Thanks for the info.
David
Pic request: clear side markers & bumper light on white XJ slrmacro XJ Cherokee Technical Forum 8 03-30-2012 05:41 PM
Clear ARB turn signal/markers 99XJer XJ/MJ Cherokee Non-Technical Forum 19 11-30-2009 07:54 AM
Tinted or Clear Side Markers? BigMike80 XJ Cherokee Technical Forum 5 02-22-2007 08:40 PM
Clear Side Markers Slammed_Am XJ Cherokee Technical Forum 8 08-06-2006 08:10 PM
Clear Corners and Side Markers 00xj54 XJ Cherokee Technical Forum 13 03-05-2006 06:48 PM
