Cleaning exhaust manifold? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Cleaning exhaust manifold?
Alloy usa heavy duty ball joint kitsBds fox ipf 2.0 racing series shocks now available at rockENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 01-11-2015, 07:07 PM   #1
Shadowkai
While under the hood today, diagnosing a heater issue, I noticed the exhaust manifold is quite rusted but it appears to be surface rust without serious penetration. Considering the Jeep was in New England for 16 years is it worth replacing the part or is there a practical way to clean and seal it? No symptoms of cracks or failure (yet!).
If the manifold should be replaced, has anyone used the kind with expansion sleeves welded onto the tubes? Any opinion? Link below.
http://www.ebay.com/itm/Stainless-St...del%3ACherokee
1998 XJ Cherokee Sport -Stock
Planned fixes/upgrades: too many to list!
Shadowkai is offline   Reply With Quote Quick reply to this message
Unread 01-12-2015, 06:48 PM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
The exhaust manifold does not need cleaning or sealing. Like the rest of the exhaust system, if the manifold fails, you replace it.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 01-12-2015, 08:37 PM   #3
PaYankee
Don't replace it until it cracks. I replaced the exhaust manifold in both of my jeeps with ones with expansion tubes. No problem with either. One has 30k miles and the other 5k on the exhaust manifolds.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline   Reply With Quote Quick reply to this message
