Quantcast Cleaning the Engine Bay - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > Cleaning the Engine Bay
Old 02-23-2009, 01:00 PM   #1
DeepSky
Hey guys.
I just bought an 87 Cherokee Larado and the engine bay is filthy. Can I just cover up the intake, spray it down with Simple Green, and power wash it off like I do with my Wrangler?
Also, it has that layer of foam feeling stuff on the underside of the hood (for heat reduction?) which is also filthy and falling apart, can I rip that off?
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(My Build Details)
DeepSky is offline   Reply With Quote
Old 02-23-2009, 01:24 PM   #2
88XJSport
1988 XJ Cherokee
You can rip off the foam pad, as mine didnt come with it stock.
As for the engine bay, do not get any water on the Thrttle Position Sensor (sensor closest to the drivers side on the throttle body) and cover the distributor. Concentrate on cleaning the engine block, and dont get too crazy with the water near any electrical connections, the relay-center, etc.
88XJSport is offline   Reply With Quote
Old 02-23-2009, 01:39 PM   #3
DeepSky
I appreciate it. Thanks for the info
Old 02-23-2009, 01:47 PM   #4
Probie101
simple green rocks but if it doesnt work go to napa get the black can of hvy brake cleaner it works alot better but DO NOT get it on your paint you have been warned
Yes I am a noob but I am learning!!!
Probie101 is offline   Reply With Quote
Old 02-23-2009, 03:58 PM   #5
Fletch8672
1975 CJ5
Purple Power works very good. You can pick it up at any Advance. I use it on my CJ & XJ and it works like a champ.
Present: 96 XJ ~Black~ , 75 CJ-5 ~Blue~
Past: 95 YJ ~Bright Mango~ , 96 XJ ~White~, 72 CJ-5 ~Baby Blue~
Remember: Owning A Jeep is a lot like having Herpes, sure it may act up from time to time but you'll never get rid of it...
~Black Jeep Society~
Fletch8672 is offline   Reply With Quote
Glock Forum
