Cherokee XJ How big can you go? - JeepForum.com
post #1 of 14 Old 06-14-2013, 02:24 PM Thread Starter
Snowbeast
1995 XJ Cherokee
Which puts more strain on the drivetrain, taller or wider tires?
Snowbeast is offline
post #2 of 14 Old 06-14-2013, 04:06 PM
Motorcharge
Wider. More rubber on the ground means more effort to move means more strain on everything. Both effect it though.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 14 Old 06-14-2013, 11:32 PM Thread Starter
Snowbeast
1995 XJ Cherokee
I guess I will stick with a 12.50 instead of going to a 13.50 or 14.50 then perhaps... Thanks!
post #4 of 14 Old 06-15-2013, 07:00 AM
Motorcharge
What axles are you running?
|SOLD|
| June 2015 COTM |
post #5 of 14 Old 06-15-2013, 02:54 PM Thread Starter
Snowbeast
1995 XJ Cherokee
I don't know what it has I bought the jeep 2 months ago and there was nothing in the ad about any upgraded axles... If I was to upgrade what brand should I look into?
post #6 of 14 Old 06-16-2013, 03:01 AM
Rockdrummer93
A 13.50 wouldnt be too bad. A buddy of mine runs 35x13.5 Toyos on his XJ, no problems
2014 Cherokee Of The YEAR
Rockdrummer93 is offline
post #7 of 14 Old 06-17-2013, 12:12 PM
JPCherokee
It comes down to axles and gearing. Figure out what you have and work from there. If it only sees pavement you should be ok. Unless you hammer it on the street, then there could be issues with all that rubber on the ground.
JPCherokee is offline
post #8 of 14 Old 06-17-2013, 05:25 PM Thread Starter
Snowbeast
1995 XJ Cherokee
It's definitely not a pavement princess, boulevard bogger, or street swamper
post #9 of 14 Old 06-18-2013, 08:07 PM
dcorn
What the hell tire are you trying to run at 13.5 or 14.5" wide? Pit Bull Rockers?? Rule of thumb is max tire size of 35" on stock XJ axles, even with maximum work done to them. I have the stock D30/29sp 8.25 with aftermarket shafts, steering, lockers, etc. and I still wouldn't go over a 35x12.5 tire.
Wrong dude. A 28x14" tire would not put anywhere close to the same stress on an axle shaft as a 33x9.5" tire. Larger tire diameter means more stress, it's all based on torque, which is based on tire diameter.
If you are talking about the same diameter, then sure, a wider tire will work the drivetrain harder because it gets more traction.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #10 of 14 Old 06-18-2013, 08:35 PM Thread Starter
Snowbeast
1995 XJ Cherokee
I wanted to try and stuff some 38's under it, but I am at peace with the nothing bigger than 35 thing... Thanks for all the input and get out there and tear it up!
post #11 of 14 Old 07-25-2013, 02:38 PM Thread Starter
Snowbeast
1995 XJ Cherokee
I guess it's time to find some Dana 60's
post #12 of 14 Old 07-25-2013, 09:15 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
No way rockwell 2.5 tons I can get a set locally for 1600. Or 5 tons for 2800
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #13 of 14 Old 07-26-2013, 03:03 AM
XJmike0122
Umm where the eff do you live??? I want in on the Rockwells. OP don't go over 35s with stock axles. You could break a rear axle doing a u turn.
XJmike0122 is offline
post #14 of 14 Old 07-26-2013, 11:02 AM
Tom95YJ
Tom95YJ's Avatar
I live in the Mecca of Offroad Utah. There is a local place that sells military trucks , axles , wheels , tires ect.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
