Cherokee safari rack - JeepForum.com
post #1 of 8 Old 05-21-2013, 01:36 PM Thread Starter
huntbigb
I have a 97 Cherokee and I'm thinking about building my own safari rack. Any suggestions on dimensions, things to consider, etc.?
huntbigb is offline
post #2 of 8 Old 05-21-2013, 02:15 PM
jeepster383
Check on emt conduit from lows. Built my own for $150 and its very light.
jeepster383 is offline
post #3 of 8 Old 05-21-2013, 02:25 PM Thread Starter
huntbigb
I saw a wooden one on a liberty yesterday. It looked awesome. I was gonna use treated wood and sand it smooth and stain it...
huntbigb is offline
post #4 of 8 Old 05-21-2013, 05:33 PM
BlueBadger
This is the one I'm currently building. It has a welded steel base with aluminum angle that is 1" by 1" 1/8th" thick pop riveted together. It's 48"s by 69 1/4". Still have to fab some gutter mount brackets. Hopefully this will give you an idea. The steel floor came off a Kobota zero turn shipping crate I got from a buddy at tractor supply. The aluminum I got for free from work. So I won't have much in it when it's done.
BlueBadger is offline
post #5 of 8 Old 05-21-2013, 06:30 PM
sluff28
1975 CJ5
if you wheel it hard remember they will be ripped off by big branches trees when your off camber and occasionally dented by rocks when your crapping your pants really off camber in the wrong spot (Yes experience with the 3) if I had to do it again I would have went a little more narrow than wide. and when you tear it off the raingutter drip molding are stupid expensive and only glued on.
sluff28 is offline
post #6 of 8 Old 05-21-2013, 09:38 PM Thread Starter
huntbigb
I don't take it "wheeling" just a little off road here and there
huntbigb is offline
post #7 of 8 Old 05-22-2013, 08:36 PM
woodyoakes
This will be my next addition. Where do you buy the legs to mount it to the rain gutter. I have a tubing bender I can bend 1".
woodyoakes is offline
post #8 of 8 Old 05-22-2013, 08:56 PM Thread Starter
huntbigb
I am going to mount mine to my existing factory roof rack. I believe you can get brackets in amazon
huntbigb is offline
