Cherokee MPG - JeepForum.com
post #1 of 22 Old 01-22-2011, 07:32 PM Thread Starter
wallick912
Cherokee MPG
Ok i know jeeps will never get good gas mileage but mine seems to be running abnormally low. Im averaging around 14 and its not lifted and it doesnt have big tires. It is a 1999 classic. I didnt know if there was a part that could be replaced like the o2 sensor that could bring the mpg back up. And also, does anyone know if jeeps have to go through a cycling or re-calibration process when the battery is disconnected like some cars do. Thanks for the any help.
wallick912 is offline
post #2 of 22 Old 01-22-2011, 07:38 PM
imthehink
imthehink's Avatar
Thats normal lol. If I remember correctly, my window sticker said 15 city 20 hwy. And thats a negative on the battery question. There are products to claim better mpg but come up short. Throttle body spacer, k&n, "cold air intake" are useless imo and a waste of money. Ive had them all.
imthehink is offline
post #3 of 22 Old 01-22-2011, 08:06 PM
misscla
I get 14 to 15 right now on my '01 too and mine is stock also.... my grand was getting 9 so I feel like im driving an econo car compared to it.
Claraaaaa
misscla is offline
post #4 of 22 Old 01-22-2011, 08:19 PM
Holder350
1995 XJ Cherokee
To remove adaptive memory from the PCM,
Remove the positive cable from the battery and touch it to a metal surface to ground it.
Replace it and turn the key ON but do not start
Turn on headlights, turn off headlights, and turn key off.
Adaptive memory has been reset.
As for the MPG, the story goes.....Buy Jeep, Get horrid mileage, complain about it, love the jeep to much to get a gas sipper.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #5 of 22 Old 01-22-2011, 11:16 PM
NJXJ91
Your lucky to get 14.
NJXJ91 is offline
post #6 of 22 Old 01-22-2011, 11:20 PM
2doorxj
2doorxj's Avatar
I have a 98 5 speed geared 3.73s, with 33x10.5. i average anywhere from 16-18 mpgs per tank. I also drive like there is an egg under the skinny pedal. When i drive more agressivly, i get 12-14.
Im telling you, its all about your driving technique.
2012 Cherokee of the Year
2doorxj is offline
post #7 of 22 Old 01-23-2011, 09:33 AM Thread Starter
wallick912
Yeah thats what i figured. Thanks for the help anyways. Its just that some people say they get 18-22 mpg but I guess they just drive highway more. But i don't really mind putting the money into gas because i like my jeep so much
post #8 of 22 Old 06-30-2012, 02:22 PM
USCGTheHoff
Im driving a 96 zj and Im getting on average 15-22 with an engines that has only had a few repairs here and there. But has 227xxx miles on it. Compared with most its pretty damn good. Still running stock.
USCGTheHoff is offline
post #9 of 22 Old 06-30-2012, 02:31 PM
Texsun
I get 0 mpg
or 69 mpg...
Texsun is offline
post #10 of 22 Old 07-01-2012, 12:38 AM
Muddy97Cherokee
1997 XJ Cherokee
Originally Posted by Texsun
or 69 mpg...
I've never heard of a jeep with a prius engine before! Please lead me to that thread, I want to save money!!! Lol
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #11 of 22 Old 07-01-2012, 07:42 AM
JGriff99xj
I can do that in mine too. Coming off an off ramp on the highway, drop it in neutral and see how high the numbers will go.
JGriff99xj is offline
post #12 of 22 Old 07-01-2012, 10:48 AM
DerMeister
14mpg is not normal IMO. Maybe in the winter with cold temps, city driving and 4wd. Start with the basics, and move to the not so basics.
Tune up,
Plugs, Rotor, Wires, ect.
Air filter
Check your engine grounds(the one from the back of the block to the firewall) and replace. Check your battery and alternator cables too.
Run some fuel injector cleaner through a few tanks.
Use proper air pressure for your tires, get an alignment, make sure your brakes aren't dragging and everything spings as it should.
Then move on to things like fuel pressure, upstream 02 sensor, exhaust leaks, vacuum leaks.
I was getting around 14.8 mpg no matter what I did with 50% City and 50% Highway driving. My driving style was average. I even got 13.8mpg one time when I was running the AC all the time.
I replaced the plus, and the firewall ground to start off my "get better MPGs" mission and I got 17mpg this fill up. 50/50 city/highway with AC.
Lifted 2" with 235's.
I'm sure I missed a few things, but you get the point. Start with the easy routine stuff, then go from there.
DerMeister is offline
post #13 of 22 Old 07-02-2012, 08:31 PM
SuperSam
stock i was getting a8 with a mix of freeway and city. I have noticed that short trips really kill the MPG. I just replaced the O2 sensor and it went up about 1mpg. You can find them for ~$30 on amazon, just look up the part # elsewhere.
x2 on the tune-up.
SuperSam is offline
post #14 of 22 Old 07-02-2012, 08:34 PM
SuperSam
****18, not a8,
SuperSam is offline
post #15 of 22 Old 07-02-2012, 08:37 PM
michaelleegarre
i have a 98 sport with a 2'' budget and 31's i get around 13-14 city i got lucky one time and got 18 idk how
Michael Garrett
1987 YJ - sold, 1995 ZJ - sold, 1998 XJ - sold, 2000 TJ
michaelleegarre is offline
'96 Grand Cherokee Seats and Center Console in a '96 Cherokee? 96cherokeesport XJ Cherokee Technical Forum 16 09-25-2010 05:35 AM
Does a 1985 Cherokee have the same bolt pattern as my 1995 Grand Cherokee?? 1995Cherokee XJ Cherokee Technical Forum 3 03-21-2010 05:48 PM
Hey Cherokee owners...Will stock 2005 Wrangler Wheels fit a 95 Cherokee? RedArrow10 XJ Cherokee Technical Forum 3 07-23-2009 11:41 AM
Swap stock wheels 99 Cherokee to 96 Grand Cherokee?? JeepsJeeps XJ Cherokee Technical Forum 2 10-09-2006 03:41 PM
Nerf Bars Cherokee/Gran Cherokee are they interchangeable? Borinquenknight XJ Cherokee Technical Forum 1 02-15-2003 01:04 AM
