Cherokee on Blocks - JeepForum.com
post #1 of 4 Old 04-10-2011, 08:40 PM Thread Starter
wretchedjeep
Cherokee on Blocks
So back when I had a truck I noticed a lot of guys went the cheap route and blocked there trucks in the rear to gain lift. My question is why don't Cherokee owners do this? I know axle wrap can be a huge problem but can be fixed with the proper use of a torsion bar. What other reasons are there to not do this?
And before I get flamed, this is not something I am considering nor will I ever consider for my rig. It just seems like a cheap and unsafe way to wheel, IMHO.
1983 Hunter Green CJ-7...R.I.P.
1994 Hunter Green XJ 4x4 4.0L H.O. 2000 Midnight Blue TJ Both Sold
2003 Black WJ Laredo Work In Progress
www.freshprintsofhouston.com
wretchedjeep is offline
post #2 of 4 Old 04-10-2011, 08:54 PM
DeftwillP
You pretty much nailed it. Also, xj springs can end up becoming flat or even negative arched, especially with blocks. They can work ok with larger trucks and much stiffer leaf spring backs.
DeftwillP is offline
post #3 of 4 Old 04-10-2011, 09:46 PM
escapeartist
Blocks are OK for street trucks, off roading would tear up a rig with blocks before long.
escapeartist is offline
post #4 of 4 Old 04-11-2011, 12:37 AM
COLOUXJ
2010 JK Wrangler
It all depends on the Springs, Stiffer HD leafs will be fine with small blocks, <1", i had 1" blocks and HD stock leafs and do not have any problems on the trails, i took them off till i could get longer brake lines though as i was streching the stock lines and did not like that. However, personally i will not run anything over 1"
COLOUXJ is offline
Blocks. BassMasterCHS XJ Cherokee Technical Forum 24 10-09-2010 09:44 AM
AAL vs. blocks robertr70 XJ Cherokee Technical Forum 5 03-04-2007 08:26 AM
Blocks... PAFirefighter11 XJ Cherokee Technical Forum 16 09-15-2006 09:49 AM
Blocks over AAL KNickels45 XJ Cherokee Technical Forum 6 07-11-2005 01:44 AM
98 Jeep Cherokee - help!!! Having trouble restarting after driving 4 blocks geetergrim XJ Cherokee Technical Forum 5 01-14-2005 05:47 PM
