changing spark plugs - JeepForum.com
post #1 of 13 Old 02-27-2012, 03:29 PM Thread Starter
morrie
After trying (without success) to pull the plug wires off the plugs, I pulled up some posts about changing spark plugs. I suppose I will have to twist & pry the wires off with a screwdriver...right? I do NOT want to damage the wires. Any other suggestions??
morrie is offline
post #2 of 13 Old 02-27-2012, 03:44 PM
GtiKyle
My suggestion...Pull harder. It's not likely to damage them,but they make special pliars if you really want to look into that. Google 'spark plug removal tool'.
1998 Cherokee, 6.5" LA, D30/C8.25 4.56 locked F/R, 35" MTR's, other goodies ...
Build thread :
GtiKyle is offline
post #3 of 13 Old 02-27-2012, 03:48 PM
Callelle
1997 XJ Cherokee
If you're changing the plugs, you'd be better off changing the wires at the wires at the same time.
Callelle is offline
post #4 of 13 Old 02-27-2012, 09:55 PM
01XJLimited
IDK how yours is, jut I have an 01 and I have a coil pack rail. The whole rail comes off, put it out of the way and go to town. But I'm new to this jeep thing, inherited from the lady. But first time doing the plugs took about 35 mins start to finish.
01XJLimited is offline
post #5 of 13 Old 02-28-2012, 12:44 AM
DullesJeep
1995 XJ Cherokee
Was going to say this exact thing. If the wires are that hard to get off, it sounds like they could use replacing anyway. When you re-install what you have, or replace your wires, be sure to use dielectric grease on your connectors. You may or may not want to use anti seize compound on your spark plug threads, I don't recommend it, but it's up to you. If you do end up using it, less is more. Be sure not to over torque your plugs, using anti seize compound on them makes them more susceptible to over torquing.
It's a Jeep thing. Sometimes I don't even understand.
DullesJeep is offline
post #6 of 13 Old 02-28-2012, 06:02 AM
cruiser54
1990 MJ Comanche
Along with the dizzy cap and rotor.........
cruiser54 is offline
post #7 of 13 Old 03-02-2012, 02:02 PM
Wolfie
When was the last time they were changed? Might be a good idea to get new ones too. Also hope you have a correct fitting spark plug socket.
Wolfie is offline
post #8 of 13 Old 03-02-2012, 03:18 PM
Millermagic
Ah ... it's nice not having to worry about caps and rotors and wires.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #9 of 13 Old 03-02-2012, 03:48 PM
TheNerd
TheNerd's Avatar
You prefer to worry about a cracked 0331? Personally, I'd take the cap/rotors worries over the head worries.
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
post #10 of 13 Old 03-14-2012, 11:28 AM Thread Starter
morrie
purchased some autolight wires and nkg plugs. All but 2 The mopar wires came off without breaking...LOL Anyway, I now have new plugs & wires. I can tell the difference. Thanks for everyone's input/advice.
morrie is offline
post #11 of 13 Old 03-14-2012, 03:20 PM
Azzy
You still have to worry about the plug boots, which are a PITA to get off my wife's 01. I dislike just about everything in that engine bay, especially because its a CA compliant model with a bajollion converters and 02 sensors.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #12 of 13 Old 03-14-2012, 08:03 PM
N8N
I just went through this with my '99... still had the original plugs and wires as far as I could tell. I ended up using channellocks to get the boots off and just replacing both. Yes some of the wires came apart, but it was time. To prevent this in the future, put some silicone grease (or dielectric grease, pretty much the same thing) on the spark plugs before putting the new boots on.
N8N is offline
post #13 of 13 Old 03-17-2012, 12:11 AM
Trombly
lol true that
Trombly is offline
Changing spark plugs Jeepguy91 XJ Cherokee Technical Forum 4 01-08-2012 03:59 PM
Changing Spark Plugs?????? rdorazil33 XJ/MJ Cherokee Non-Technical Forum 4 10-29-2009 12:47 AM
Changing spark plugs EJames1226 XJ Cherokee Technical Forum 9 05-27-2006 01:21 PM
changing the spark plugs on an '01??? ChiTown'01XJ XJ Cherokee Technical Forum 12 05-27-2005 12:40 AM
Changing spark plugs NIN_Jeep XJ Cherokee Technical Forum 9 08-07-2002 06:49 AM
