changing to 4h - JeepForum.com
post #1 of 9 Old 05-05-2011, 07:18 PM Thread Starter
rayian
1997 XJ Cherokee
changing to 4h
Hi people. I just picked up a 97 Cherokee. In my old 88 Cherokee I used to be able to change from 2H to 4H while rolling but that was with a standard transmission. I'm wondering if it's the same with the auto transmission in the 97.
rayian is offline
post #2 of 9 Old 05-05-2011, 07:25 PM
MagicNelson
I have an auto trans and I find it easiest to switch when rolling in neutral.
MagicNelson is offline
post #3 of 9 Old 05-05-2011, 07:57 PM
string378
I can shift on the fly with my auto
string378 is offline
post #4 of 9 Old 05-05-2011, 08:09 PM
AeroSync
I shift from 2H to 4H or 4PT while on the fly in Drive.
I drive an Orange.
AeroSync is offline
post #5 of 9 Old 05-05-2011, 09:00 PM
rugsucka
You don't need to be in neutral, but I let off the gas-pull back on handle-lay on the gas all while remaining in Drive.
Don't engage your transfer case while doing retarded speeds. If you need 4wd then you shouldn't be driving that fast.
You vote last monday?
rugsucka is offline
post #6 of 9 Old 05-05-2011, 09:42 PM Thread Starter
rayian
1997 XJ Cherokee
Thanks for the responses.
I'm was born in England and not a Canadian citizen so not eligible to vote.
rayian is offline
post #7 of 9 Old 05-05-2011, 09:50 PM
rugsucka
Then you must have watched the wedding!! Did you see the second kiss?
rugsucka is offline
post #8 of 9 Old 05-05-2011, 10:16 PM
90xjblue
1990 XJ Cherokee
hahahhahahahaha
90xjblue is offline
post #9 of 9 Old 05-05-2011, 10:26 PM Thread Starter
rayian
1997 XJ Cherokee
i missed that. Right in front of the kids. Unbelievable.
rayian is offline
changing gear changing pattern (auto trans) cheepjeep96 XJ Cherokee Technical Forum 12 10-17-2008 11:25 AM
Changing the ECU t0ast3d XJ Cherokee Technical Forum 8 07-24-2007 04:39 AM
Changing Oil lrsmithwhaley XJ Cherokee Technical Forum 13 10-24-2005 06:22 PM
changing the look TJSahara XJ Cherokee Technical Forum 1 05-19-2004 11:34 AM
Changing Oil Jer1458 XJ Cherokee Technical Forum 13 09-16-2003 04:11 PM
