Changed rear main seal today. What a PITA! - JeepForum.com
post #1 of 6 Old 03-01-2013, 10:00 PM Thread Starter
WestTennXJ
Remove oil pan bolts, remove pan, pull rear main bearing cap and replace seal, reinstall everything. Sounds easy. After 4 hours on my back I'm feeling pretty beat up. Some highlights:
-Can't fit socket on rear oil pan bolts. Curse some before removing starter to free up the shield enough to make it work
-Can't get pan out. Curse some more. Jack up XFR case to create enough clearance.
-Can't get old seal out of block. Curse some. Grind the head off an old screwdriver to make a seal pusher.
-Damage new seal while installing. Curse. Go to store to buy new one - out of stock. Curse some more.
-Finally get the pan and gasket back in place and get most of the bolts snugged up. Realize I forgot to reinstall the crank girdle. Curse - A LOT this time, and I think the trash collectors were at my house and heard me this time.
2000 Cherokee Sport, 4WD Auto 4.0
2013 F150 4WD Ecoboost
2012 WK2 Limited (Wife's)
WestTennXJ is offline
post #2 of 6 Old 03-01-2013, 10:11 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
This makes me think maybe I could endure the leaky on my '96 a little longer.
***Chris***
chris87xj is offline
post #3 of 6 Old 03-01-2013, 10:29 PM
Motorcharge
**** like this is why I haven't quit my job at a dealership. Having access to the shop and lifts on weekends is priceless.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #4 of 6 Old 03-04-2013, 07:45 AM
bobthecatkiller
Now i need a job at a dealership.
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #5 of 6 Old 03-04-2013, 09:42 PM
Hussler
1992 XJ Cherokee
Got to do this on the girls Jeep in a couple days, was very easy on mine but mine has 5" of lift. Did you jack up the jeep at all? I feel like I had more than enough space to work
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #6 of 6 Old 03-05-2013, 06:04 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I suspect mine needs a new RMS but Ima give it some time to see if the leak is chronic and severe enough to dig into a project like this. From what I understand this job can drive a mother****er to straight madness.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
