Center Console Mods - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > Center Console Mods
ZONE 4.25" combo lift for TJ available at Rockridge4wJeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinRIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 09-11-2014, 09:32 AM   #1
SmashDN
Center Console Mods
Leaned across into the passenger seat the other day and heard plastic cracking. Console mount bracket is toast now.
Opened it up to take a look and sure enough it is in pieces. Followed the links here to the "other" jeep forum and sent that fellow a message but got no reply for a week now. Luckily I have several pieces of sheet steel at my desk at work to make a bracket. I think it is .22" thick enameling steel.
While in there I took notice of the AC/heater vent tube in there. I have already picked up some of the air bubble duct insulation stuff for going under my headliner board and thought it might not be a bad idea to insulate that plastic tube. Probably won't make a nickel's worth of difference but it will make me feel better. Also, the tube stops probably 1/4" before it makes it to the vent slots so I am going to make some kind fo flexible gasket to try and get all that air out the vents as designed.
Any other center console mods I should think about while I have it out messing with it?
SmashDN is offline   Reply With Quote Quick reply to this message
Unread 09-13-2014, 02:33 PM   #2
Kevin108
Fix it for $3. http://www.jeepforum.com/forum/f177/...l#post14785173
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline   Reply With Quote Quick reply to this message
