CB Antenna - JeepForum.com
post #1 of 8 Old 11-10-2013, 08:36 PM Thread Starter
ParkerXJ
CB Antenna
need some help, I'm not even close to experienced with wiring and whatnot, my history with CB radios is strictly at work on boats
but I'm looking to remove the radio antenna from the hood of my XJ, and possibly mounting it in the rear of the jeep, using a bracket and finding a write-up
if i removed the radio antenna can i rewire it to come out of the cb antenna? or could i simply relocate my radio antenna by the rear hatch
any help/criticism appreciated, and please remember, I'm new to the wiring and even mechanical tasks, so please be easy, I'm here to learn
thanks!
2001 Jeep Cherokee XJ Limited -3.5" Rubicon Express Super-Ride kit, H4 headlights
ParkerXJ is offline
post #2 of 8 Old 11-10-2013, 08:39 PM
Motorcharge
The radio antenna is literally a single piece of wire. If you can drill a hole and route the wire you can move where ever you want. CB is nothing but a positive and a negative and a single coaxle for the antenna. Google CB installs, there's a million write ups out there for what you do and don't want to do with a CB.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 8 Old 11-10-2013, 09:01 PM Thread Starter
ParkerXJ
also im not planning on putting a CB radio in my jeep, just like the look of the black CB antenna, so can it be used as radio? and just run the wires back through the jeep on the passengers side
ParkerXJ is offline
post #4 of 8 Old 11-10-2013, 09:02 PM Thread Starter
ParkerXJ
ohh okay, gotcha! thanks for not judging me, I'm learning
but thats what my plan is, thanks for the help!
ParkerXJ is offline
post #5 of 8 Old 11-11-2013, 01:00 PM
Muddy97Cherokee
1997 XJ Cherokee
No, a cb antenna can not be used as an AM/FM radio antenna. Different frequencies. You would have to cut the wire within the CB antenna to match that needed for those frequencies. Also, running a radio antenna, really any antenna, within 102", 8', of a CB antenna will cause CB interference.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #6 of 8 Old 11-11-2013, 01:51 PM
Agility
1997 XJ Cherokee
Check out this Firestik article from 1996. I had it in my bookmarks; when I get around to putting CB back in I might look into this. I haven't done any other looking but this might get you started.
http://www.firestik.com/Tech_Docs/am-fm-cb.htm
Agility is offline
post #7 of 8 Old 11-11-2013, 03:16 PM
Motorcharge
No, but you can just buy an AM/FM antenna like that. They just screw on.
|SOLD|
| June 2015 COTM |
post #8 of 8 Old 11-11-2013, 05:26 PM
Soldier905
1988 MJ Comanche
Some second gen firebirds had radios that were both CB and Am/FM which used the same antenna for both. The only issue i ever heard out of them was the antenna as it was telescopic and it would get stuck at times.
Soldier905 is offline
xj
