Can't get the oil fill cap off. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Can't get the oil fill cap off.
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-11-2013, 05:10 PM   #1
RonC777
I know. This is ridiculous, but I can't get the cap off to add oil. It just keeps snapping when i turn it. ( Yes. I am turning it to the left.) I'd appreciate any help.
OK. I probably posted this to the wrong place, but could still use some advice.
RonC777 is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 05:14 PM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Buy a new cap. Pry off the top cover of the stuck oil fill cap. Drop a large coin that will span from one side to the other, into the bottom part of the cap that will be still be stuck in the valve cover. Twist the coin with a pliers.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 05:44 PM   #3
RonC777
Yeah. I'm a bonehead. I just pushed down as hard as I could and it came off. Thanks for the help though.
I like your Ronald Reagan quote.
Unread 07-14-2013, 09:42 PM   #4
ECL
A bit late but I have the same problem with mine. I've found that it only does it when the engine is hot. If I let the engine cool down, the cap will come right off. Some day I'll buy a new cap but for now, my simple but elegant solution is to just do my oil changes with a cold engine. Fortunately it doesn't burn oil so I rarely have to pull the cap off between changes.
ECL is offline   Reply With Quote Quick reply to this message
