Can't fill the gas tank - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Can't fill the gas tank
Income tax season is upon us. We got what u needGet 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!
Unread 09-19-2014, 12:21 PM   #1
Ocs1667
1989 XJ Cherokee
Really frustrated. It takes me 15min or more to fill the tank. If close to empty it takes about 4-5 gal. with no problem, at that point it shuts off. At that point I have to fill it holding the gas handle and pumping it very slowly. It stops often when the gas backs up.
1. I have replaced both the fill hose and vent hose.
2. I replaced the fuel tank when I was building the Jeep. The tank had a large dent in it so I replaced it with a new one.
3. Every thing forward of the gas tank is Chevy, including a charcoal filter that I read that it can be defective causing this problem. They suggested blowing air through it to unclog any obstruction. which I did. Did not help.
Any Ideas would be appreciated.
Thank you in advance
Dennis
Ocs1667 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 09:25 AM   #2
Renix
1989 XJ Cherokee
I've never had this problem on a xj.... Have on other vehicles. It usually boils down to one of two things.
filler neck is not ventilating or charcoal canisters are bad and building up pressure.
The reason twitter flourishes is because very few people can comprehend past 140 characters.
Renix is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 06:35 PM   #3
MarkwithaK
It happens on mine from time to time. Usually I pull the nozzle back a bit and it flows with no problem.
MarkwithaK is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 08:56 PM   #4
XJkid01
Casual
XJkid01's Avatar
Happened to me this evening, I just sat for a little while then moved to a different pump, worked perfect
XJkid01 is online now   Reply With Quote Quick reply to this message
