This can't be right? - JeepForum.com
post #1 of 14 Old 07-27-2011, 02:35 PM Thread Starter
freestylekid33
Yesterday i checked my fuel mileage and burnt 1.9 gallons in 53.4 miles. I know my speedo being off messes it up but it cant be that much? When my speedo says im doing 65 im doing 70 on my gps. Can anyone help me figure out what i am actually getting for MPG because there's no way i'm getting around 27 MPG in a xj on 32's with stock gears lol.
freestylekid33 is offline
post #2 of 14 Old 07-27-2011, 02:45 PM
FleshEater
2014 JK Wrangler
So you went to the gas station after a 53.4 mile trip and topped your tank back off with only 1.9 gallons?
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #3 of 14 Old 07-27-2011, 02:56 PM Thread Starter
freestylekid33
Yes sir that is correct, it doesnt sound right does it? I thought my jeep was gonna shrink into a prius on the ride home from the gas station
post #4 of 14 Old 07-27-2011, 03:24 PM
Kevin108
That's not how you check mileage.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #5 of 14 Old 07-27-2011, 04:24 PM
Kettles
Thats way too short of a trip to even get an idea. Every pump is going to cut off at a slightly different time, and therefor fill to a slightly different level. The best way is atleast 2 tanks full, averaged together.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #6 of 14 Old 07-27-2011, 09:12 PM Thread Starter
freestylekid33
I figured it would be the same? I used the same pump at the same station... I guess ill try again and wait till i go further to fill it, is there any way to figure out how many miles i actually go with my odometer being off because of my tires?
post #7 of 14 Old 07-27-2011, 09:31 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
With your actual speed being 1.077 times your speedo reading, your odo readings are likely off by a similar ratio. Thus 100 miles on the odo may equate to about 107.7 actually traveled.
I'd guess the gas pump hiccupped and shut off before your tank was completely full. My 96 will do the same if I run the pump at full blast.
***Chris***
chris87xj is online now
post #8 of 14 Old 07-28-2011, 07:53 AM Thread Starter
freestylekid33
Ok cool thanks for the info, i guess ill fill it a couple times then and check it after that so if something like that happens it wont make near as big of difference lol...
post #9 of 14 Old 07-28-2011, 01:01 PM
jeepdavetj
1991 XJ Cherokee
If your running larger tires on the highway with stock gears for 57 miles, I could see 27 mpg out of an XJ. As long as there was no hills and it was flat or down hill. Meh.
I don't blame people for their mistakes, but I do expect they pay for them.
Ash from Army of Darkness
Alright you Primitive Screwheads, listen up! You see this? This... is my boomstick! The twelve-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about a hundred and nine, ninety five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You got that?
jeepdavetj is offline
post #10 of 14 Old 07-28-2011, 06:00 PM
tdavidk76
Doesn't it work the other way around when you have bigger tires? Because your tires are going to make fewer rotations in a mile. making your speedo show that you have traveled less miles than you actually have and trowin off your calculation.
Ted - 2001 XJ Sport, Patriot Blue. HD rear springs (1"-1.5" lift). Rusty's-1.5" shackles, 3" coils, LCA (custom for factory wheels). 31 10.50 15
tdavidk76 is offline
post #11 of 14 Old 07-28-2011, 06:58 PM
Brookhart63
Take the circumference of a 28 inch tire then take it of a 31. The 31 is much longer. 1 rotation of the 31 means more distance traveled than the 28, but the speedo will still only count one roatation. My jeep with 31's goes 1.12 REAL miles for every 1 JEEP mile.
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline
post #12 of 14 Old 07-28-2011, 07:27 PM
cdawall
1994 XJ Cherokee
i answered this on another forum
Originally Posted by cdawall View Post
so quick break down to work it out since people are asking
200 miles on your stock setting odo for a jeep that came stock with 225/75R15 (28.29") after installing 285/75R16 (32.83") and used 12 gallons
32.83*pi=103" for a full revolution
28.29*pi=88.83" for a full revolution
63360" in a mile
63360*200=12672000 inches in 200miles
12672000/88.83=142654 revolutions of the tire in 200 miles
142654*103=14693414" actual inches traveled by a 285/75
4693414/63360=232 miles traveled
232/12=19MPG
Wheeler '05 Ranger Edge SAS'd, 5.38's, D60/D60u, 38.5s
Family SUV '94 XJ 3.55's, D30/35, 315/75R16's
cdawall is offline
post #13 of 14 Old 07-28-2011, 09:35 PM
the_weirdo
the_weirdo's Avatar
That is the long way to do the math, the short way is to do it like this:
32.8" new tire / 28.3" old tire = 1.16 ratio between new and old
200 miles indicated * 1.16 = 232 miles acutally travelled
232/12 = 19MPG
the_weirdo is offline
post #14 of 14 Old 07-28-2011, 09:38 PM
cdawall
1994 XJ Cherokee
232/12 = 19MPG
yup but it is very very exact and someone asked i was specific.
cdawall is offline
